No power at fuel pump
Old Mar 9, 2014 | 10:43 AM
John_murch's Avatar
Default No power at fuel pump
Hi everyone, any ideas on why I have no power at my fuel pump on my xjs?.
Old Mar 9, 2014 | 10:50 AM
Ezrider's Avatar
could be a fuse a relay or the fuse-able link on the pump harness
Old Mar 9, 2014 | 01:23 PM
sidescrollin's Avatar
do you haven no power, or no ground?
Old Mar 9, 2014 | 02:17 PM
Steve M's Avatar
Could the inertia switch have tripped?
Old Mar 9, 2014 | 02:22 PM
John_murch's Avatar
Hi guys,checked inersher switch which is down,checked terminals with a metre on fuel pump and no power at all.hot wired pump straight to battery ,pump only done a sort of donk donk when I flashed the terminal on the battery.
Old Mar 9, 2014 | 03:57 PM
Doug's Avatar
What year and engine?
Old Mar 9, 2014 | 05:33 PM
John_murch's Avatar
Hi Doug it's an 89 3.6 auto,fuel pump relay is under passenger footwell with main relay and ecu it just stopped when I pulled it out of garage.engine has spark to plugs and cranks.just something to do with fuel to engine me thinks ?.
Old Mar 9, 2014 | 06:25 PM
Doug's Avatar
I'm not familiar with the 3.6 fuel pump circuit so I'm no help in trouble shotting why it isn't being powered-up
But, when jump-wired, the pump should hum....not go 'donk'. If nothing else it sounds like the pump might be kaput.
Old Mar 9, 2014 | 07:03 PM
Ezrider's Avatar
i had a issue with mine, they had just put a new fuel pump in just before i bought it and i started having a intermittent no run issue of the fuel pump. i was getting power to the plug in back near the batt. but pump not running.
took the plate off that holds in the fuel pump and without removing the tank had access to the plug ins for the fuel pump, tested power at the fuel pump side of the harness no power. tested at the connector side near the battery had power. removed the harness and there is a fusible link in the harness right near where it plugs into the top of the fuel tank, and that is where my issue was.
if you jump the fuel pump and it just goes clunk and not hummm your fuel pump is likely bad. your bad fuel pump may have taken out the fuse-able link though.
Old Mar 10, 2014 | 12:12 PM
John_murch's Avatar
Thanks guys I'll look for the fusible link, many thanks.
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
ccfulton
Sep 20, 2015 05:15 PM
1964Daimler
Sep 9, 2015 11:28 AM
Sprayall
Sep 3, 2015 07:49 PM
