OBD2 Scanner for 1995 XJS V12
Old May 27, 2014 | 02:27 PM
sfischthal's Avatar
Cool OBD2 Scanner for 1995 XJS V12
My service center says my 1995 JAG XJS V12 has a OBD2 port. Can anyone recommend a scanner that they KNOW works with this engine/year/model
Old May 27, 2014 | 02:49 PM
Vee's Avatar
Vee
They should all work.
I just ordered one from Amazon for about $16.
Amazon.com: Excelvan U480 Car Auto Diagnostic Scanner OBD2 OBDII CAN-BUS Code Reader Memoscanner: Electronics Amazon.com: Excelvan U480 Car Auto Diagnostic Scanner OBD2 OBDII CAN-BUS Code Reader Memoscanner: Electronics
It works on my 1996 XJS for all "P" codes. I don't know of anything that will read ABS codes unfortunately.
I believe that the Autel MD802 might as well as the AutoEnginuity, but I don't believe there's anyone that can verify that.
Old May 27, 2014 | 02:50 PM
Vee's Avatar
Vee
Oh, and I also use Movi Pro, which has a lot more features. Trouble is that it is a program, so you need a laptop to operate it.
Not sure if anyone is thrilled with anything designed for iPhones or Androids yet.
Old May 27, 2014 | 06:58 PM
AllanG's Avatar
I do not believe that the 95 XJS V12 had OBD-II capabilities. It was OBD-I compliant only I believe
Old May 27, 2014 | 07:01 PM
AllanG's Avatar
Vee, Fusion for iOS and Torque for Android are excellent scan tools for the money. They have a lot of capability for the money.
Old May 28, 2014 | 01:15 AM
dsetter's Avatar
1995 V12 is not obd-II so the port is only manufacturer codes. Standard codes did not come till obdII in 1997. I think the 4l six is obd-II.
You will only get codes like FF64 and such in the trip computer.
I do use android torque and an elm adaptor on all modern cars to good success.. There is nothing much on apple as they do not support Bluetooth programming well enough for the required data transfers.
Old May 28, 2014 | 06:56 AM
Vee's Avatar
Vee
I'm assuming Torque and the other programs do not read ABS codes...
I wonder why it's so hard to put together a program that reads them all at this point. They can stick every single Atari 2600 game ever made into a flash drive, but you still have to pay thousands of dollars for something to read a 4 digit number....
Old May 28, 2014 | 06:33 PM
sfischthal's Avatar
Unhappy Thanks, But!
Thanks for all the replies.... but just like the service centers the mix still leaves me unsure if I can or cannot use OBDII scanners....:icon_sultan :
Old May 29, 2014 | 06:16 AM
Vee's Avatar
Vee
The investment is minimal and can be used with other cars.
I say you just buy a cheapie and see if it works. At worst you'll be out $20, but again, you'll have something that can be used with other cars.
Old May 29, 2014 | 06:56 AM
AllanG's Avatar
No you cannot use an OBDII scanner on the XJS V12, only the 6 cylinder AJ16 95 and 96MY cars have this capability.
Correct they will not read Body, ABS etc codes. Because those codes were not mandated or standardized for OBD-II, you need software that has special add on packs for each brand. For instance Autoenginuity with Jaguar pack. It would probably be economically unfeasible to offer this as a phone app?
Again the scanner will not work with a 95 XJSV12
Fusion from OBDsoftware works perfectly with Apple iOS devices and is very similar to Torque in spec and function.
Old May 30, 2014 | 09:47 AM
dsetter's Avatar
Could a 95 v12 ECU be replaced by a 96 to get OBDII or was the whole year a totally different build?
JWheeler
Nov 22, 2019 08:28 AM
alextoevs
Sep 20, 2015 05:21 PM
Jaguar_libra
Sep 10, 2015 11:05 AM
Jaguar_libra
US Western
Sep 9, 2015 04:20 PM
d a
Sep 3, 2015 02:34 AM
