Oil filter
Old Sep 11, 2016 | 08:10 AM
BradsCat's Avatar
Default Oil filter
I am going to change the oil on my 87 XJS V12. Looking for recommendations on what oil filter to use, and what NOT to use.
I am planning to go with 20W-50W natural oil for 8 qts and blend with 3qts Mobil 1 Syntec.
Thanks, Brad
Old Sep 11, 2016 | 08:12 AM
Daim's Avatar
Just use a factory filter. They don't cost much.
Old Sep 11, 2016 | 08:32 AM
Greg in France's Avatar
As to the oil, I think it would be better with winter coming to use a 5W-40 oil, which is less thick in the cold than a 20W-something, so gets round a cold engine better.
I always use fully synthetic, but there are a million opinions out there, all different!
Greg
Old Sep 11, 2016 | 09:48 AM
Doug's Avatar
Over the 20 years (and various Jags) I've used the following with happy results....
Jaguar EBC9658
Delco PF964
NAPA 1231 (same as WIX)
Fram PH2995
WIX 61231, 51231
Bosch 72147
My favorite lately, however, is the Baldwin BT292
Any of the above will be fine, and many others as well, no doubt.
Old Sep 11, 2016 | 10:47 AM
Doug's Avatar
One consideration is filter length. On the V12, esp with cat converters, the longer filters are bit easier to remove. I can't remember which of the above, if any, are longer.
It seems to me that eons ago Jaguar offered a V12-specific filter that was slightly longer then the others. Later, all choices were rationalized into the single EBC9658....which is used on a very wide variety of Jags spanning decades.
If the mood strikes you can do some cross referencing on filter websites, using any of the above numbers, and almost surely find a candidate that is longer than the others.
Old Sep 11, 2016 | 05:43 PM
BC XJS's Avatar
Fram sucks. Cheap construction.
Fram= orange can of death
Old Sep 11, 2016 | 07:31 PM
Doug's Avatar
Over the years I've used dozens of Fram filters on a variety of cars, including Jags, and I can 100% assure you that nothing bad happened. Presumably you have some direct experience to the opposite? Like an engine failure or similar?
Fifteen years ago or so when all the bad press about Fram came out I stopped using them for quite some time, despite my experience of having no problems whatsoever with them over the years. I ended up feeling a bit silly. I started using them again a few years ago, along with other brands.
Later I found out that some Frams are better (or worse) than others. The blanket condemnation of years prior seems to have been a bit over-reaching. Unfortunately I don't recall if the 2995 as used on our Jags was ever checked in depth to determine where it falls in the spectrum.
For a few years I used only the genuine Jaguar-labeled filters. I have no idea whatsoever how thy compare to others but it was a 'feel good' phase that I went thru.....much like the Baldwin thing.
I have a supply of Baldwin filters for my Jag that'll last quite some time so I wont be faced with any gut-wrenching filter decisions for a couple years at least
Old Sep 12, 2016 | 03:18 AM
Daim's Avatar
I've had good experiences with Jaguar original as well as MANN and Mahle.
Old Sep 13, 2016 | 06:47 PM
mghirsch's Avatar
I stopped using the regular Fram filter in all my cars.
NTL1991
XJ XJ12 ( X305 )
Dec 1, 2016 08:02 AM
XJ-Executive
Sep 11, 2016 06:25 PM
Paul Shashaty
Sep 9, 2016 11:19 AM
orangeblossom
Sep 8, 2016 01:04 PM
Atlastajag1
Sep 8, 2016 09:23 AM
