oil leak
Old Mar 25, 2023 | 04:57 PM
ray13's Avatar
Default oil leak
How do I fix a leak where the 2 lines from the oil filter go into the block?
Old Mar 26, 2023 | 07:18 AM
garethashenden's Avatar
Which engine?
Old Mar 26, 2023 | 07:31 AM
ptjs1's Avatar
ray13,
I'm a bit confused. Although you haven't said here, i think you have a 4 litre car? In which case the filter is mounted to a plate directly to the block. There aren't any lines that go from the filter to the block.
Paul
Old Mar 26, 2023 | 05:29 PM
Brewtech's Avatar
Oil cooler lines? Those tend to leak. If you live a hot climate dont delete them. Have them remade using your original couplers
Old Mar 27, 2023 | 07:07 AM
Vee's Avatar
Vee
Just waiting for a model year and engine…
Old Mar 28, 2023 | 05:29 PM
ray13's Avatar
Old Mar 28, 2023 | 07:18 PM
Vee's Avatar
Vee
https://www.jaguarforums.com/forum/x...l-pics-160138/
Thanks. Many years, many engines. It helps to know what you have so we can help. That being said, see if that post there helps.
ExcelsiorZ
Sep 14, 2024 08:57 AM
Gilxj695
Jan 25, 2023 12:40 PM
perfectphoto
Dec 16, 2021 07:14 PM
stran0020
Oct 26, 2021 06:25 AM
drinkycrow
Oct 28, 2015 08:49 PM
