oil leak
Old Aug 21, 2010 | 01:57 PM
nosox's Avatar
Default oil leak
Hey guys,my oil leak is getting worse now.I believe its the banjo fitting behind/beside the filter.Am I right that oil will actually squirt from there under pressure?I intend to replace the brass washers and the filter since it needs to come off anyway.Any other suggestions will be appreciated.
Old Aug 22, 2010 | 04:27 AM
Les,
That pipe etc sees normal oil pressure, as soon as the engine cranks, or close to that time, and that can be 80+psi. The washers can leak, and it has been known for the metal pipe to fracture very close to the banjo. Apparently from vibration, and/or misfitment.
The other end/s of that pipe are at the centre pedastal, and the back of each cylinder head, which of course means nothing unless the pipe needs to come off coz it is cracked, hope not for your sake, real PITA job.
Old Aug 22, 2010 | 09:22 AM
nosox's Avatar
thanks Grant,I'll try to get after those banjo washers today and see how we do.As you say hope pipe is ok although leak seems localized around the fitting.
Old Aug 23, 2010 | 05:15 PM
nosox's Avatar
Mission accomplished!!! Thank you to the inventor of the gear wrench and my Dad for my little"girlie" hands.Some guys must have a lot of fun in there.
Boeingtravel95
Sep 14, 2015 05:01 PM
jaggermang
Sep 8, 2015 07:07 PM
OkieTim
Sep 8, 2015 04:48 PM
Dymaxxion
Sep 4, 2015 02:40 PM
OkieTim
Sep 2, 2015 12:48 PM
