oil leaking from my intermediate gear covr AJ6
Old May 6, 2026 | 04:34 PM
monkfe's Avatar
Default oil leaking from my intermediate gear covr AJ6
So I just finished up a timing chaing install, and other various top end stuff....upon starting up the engine today, I noted an oil leak from the intermediate bearing cover. There is no seal on this opening, just a mechanical fit of sorts. There is also a weep hole at the bottom to vent to atmosphere, which is where the oil is coming from. I did note the oil pressure is at 80, but i had changed the sending unit when I had everything apart, so could just be cheap chinese junk. Anyone ever run into this before?
Dukejag
Mar 4, 2025 05:13 AM
Gilxj695
Jan 25, 2023 12:40 PM
pyohannes
Apr 15, 2020 08:45 PM
Forcedair1
Jul 23, 2017 12:29 AM
brinny
Apr 23, 2016 08:44 AM
