oil leaking from my intermediate gear covr AJ6
So I just finished up a timing chaing install, and other various top end stuff....upon starting up the engine today, I noted an oil leak from the intermediate bearing cover. There is no seal on this opening, just a mechanical fit of sorts. There is also a weep hole at the bottom to vent to atmosphere, which is where the oil is coming from. I did note the oil pressure is at 80, but i had changed the sending unit when I had everything apart, so could just be cheap chinese junk. Anyone ever run into this before?
Gilxj695
Jan 25, 2023 12:40 PM
