Ok, so I guess it must be ignition and not trans??
Old Feb 20, 2018 | 03:44 AM
  #41
Greg in France's Avatar
Originally Posted by 944xjs
I still have a feeling I "broke" the distributor advance since it won't snap back.
Whether you or someone else, it is broken and must be fixed.
Old Feb 20, 2018 | 06:00 AM
  #42
944xjs's Avatar
Originally Posted by greg in france
whether you or someone else, it is broken and must be fixed.
Old Mar 2, 2018 | 05:35 PM
  #43
944xjs's Avatar
Whelp interesting new development.. put in a new alternator and now it revs to redline! The car revs and just feels stronger all around. Seems weird that the car didn't have the energy to rev?!
Old Mar 3, 2018 | 08:33 AM
  #44
JigJag's Avatar
Very interesting development. What voltage was it running with? Did you have any other indications that the voltage was low? Im assuming so since you put in the new alt.
Still, fix both those advances.
Old Mar 3, 2018 | 09:26 AM
  #45
944xjs's Avatar
it was charging very low since I bought it a year ago and then it was just dead... I went to drive it to storage before winter and it died on the road. It's charging like 14.3v at idle now. But yeah the advance is getting done as soon as I can.
Old Jul 18, 2018 | 10:50 PM
  #46
944xjs's Avatar
Just a quick update... most have gotten lucky the day it revved to redline cause it only wants to get to about 4500 still. I did a test yesterday and I’m only getting 82mph in second at 4500rpm then it bucks like a bronco! I need to get some distributor advance springs and get in there and fix it.
Anyone know where to get advance springs??
Old Jul 19, 2018 | 07:22 AM
  #47
Segfault's Avatar
I'd take it apart first and see what's wrong. Maybe the weights are stuck and there is nothing wrong with the springs.
Old Jul 19, 2018 | 09:13 AM
  #48
JagCad's Avatar
Well, this is from afar.
1. The engine timing is not working properly. One or both of the advance mechanisms is not there. Vacum and/or mechanical, the latter works via centrigugal force.
2. No snap back is as clear as can be the timing isn't at optimum.
3. One can use a strobe light. the advance one to read degrees that the engine fires at differing RPM's.
4. Until the distributor is either replaced with a good one or fixed, the engine will not run at its best ,
Carl
Old Jul 19, 2018 | 03:45 PM
  #49
944xjs's Avatar
Carl
yeah, it’s been a project when I got it it was running on 11 cylinders. I love the feel of this engine and I know I’ve never even it fully running right. I can’t wait till I can get it back to spec! There’s a junkyard xjs near by I think I’m going to just get the distributor off it.
Old Jul 19, 2018 | 05:14 PM
  #50
Segfault's Avatar
Does this junkyard car have cruise control actuator?
Old Jul 20, 2018 | 12:27 AM
  #51
Doug's Avatar
Try David at :
Everyday XJ
Held in high regard around here, and for good reason. Good guy, good parts, good service, good pricing
Old Jul 20, 2018 | 01:32 AM
  #52
944xjs's Avatar
not sure but if it does... I need it. 😬
Old Jul 21, 2018 | 04:45 AM
  #53
944xjs's Avatar
Well went to the junkyard today and got a whole distributor, cruise control actuator and front headlight surround for..... $45. Haha
the distributor seems to be in perfect condition. I kinda just want to replace the whole thing.
Old Jul 23, 2018 | 09:24 AM
  #54
knares's Avatar
some junkyard, lucky man
Old Jul 23, 2018 | 10:40 PM
  #55
944xjs's Avatar
yep, last year I got the ccv and a nardi steering wheel for like $40. Nice place and people
Old Jul 26, 2018 | 01:59 PM
  #56
944xjs's Avatar
Ok quick question... how hard is it to reinstall a distributor? I yanked one out of a junkyard car and everything on it is good so I just want to put it in mine. I know it’s all about the timing, but if the distributor rotor is let’s say perfectly pointing left can the new distributor be put in with it aimed exactly the same? I have never replaced a distributor.
Old Jul 26, 2018 | 05:30 PM
  #57
JigJag's Avatar
As you pull the dizzy out its shaft will rotate to disengage the drive gears. If you set the new one up the same ( match spacing on slotted Allen head screws in the base ) and pre-rotate the shaft to match how your OEM aligned on removal it should be close to the same timing. Ish.
Id set the engine to TDC first. Do not rotate it backwards! Forward only.
This is assuming you have the correct dizzy to begin with. The case should be marked.
Old Jul 26, 2018 | 11:19 PM
  #58
944xjs's Avatar
i always see everyone says move to tdc, not doing this before, I guess I don’t see how that helps? It will still need to be lined up correctly when installed. Is it just easier to know where to line up the rotor? Thanks
Old Jul 27, 2018 | 04:44 AM
  #59
knares's Avatar
yes
Yes if you can line it up exactly the same but you also have to have the distributor in exactly the same position as well and that would be the hardest part
To be out with the rotor, you would have to be a minimum of one tooth, so that would be obvious
But you have to be right on with the position of the distributer
Old Jul 27, 2018 | 02:28 PM
  #60
944xjs's Avatar
yes
ok yeah I see what you’re saying...hypothetical? If you’re off by a tooth.. will it blow up? 😬 ha
Truck Graphics
Sep 25, 2018 02:12 PM
dragudo
Nov 4, 2016 10:06 AM
seawind
Feb 1, 2016 12:33 PM
rothwell
Aug 20, 2013 10:45 AM
