Opticell wires (fiber optic) - where do they go?
Old Sep 22, 2018 | 07:57 PM
NJ2003XJ8's Avatar
Default Opticell wires (fiber optic) - where do they go?
Hello,
Finally I am replacing/installing opticell optical wires. Does anyone have diagram how they supposed to run?
So far I figured five on the climate control:
- one goes to 'air' on the slider,
- one goes to 'up' arrow
- one goes to 'down' arrow
- one to right control (AC)
- one to left control (temperature)
I see two more long ones are going under the dash. Where do they go? Ignition and parking light switch? If they do - mine are not working. How difficult is to access them (for replacement), If I take off that panel below steering column - will it be enough?
Are there any more wires that I need to run?
Thank you?
Old Sep 25, 2018 | 01:18 PM
sidescrollin's Avatar
Yes the ignition and headlight switches both use them, easiest thing to do is just take the screws out and pull the panel out some to pop them in place
Old Sep 25, 2018 | 04:15 PM
NJ2003XJ8's Avatar
Thank you.
dayton
Oct 1, 2015 06:34 PM
piluim
Audio/Visual Electronics
Jan 30, 2015 03:27 AM
Someones Addiction
Mar 13, 2010 02:09 AM
ricardoa1
Mar 2, 2010 12:06 PM
