Panel light
Old Apr 26, 2017 | 01:52 PM
jkann1's Avatar
Default Panel light
Hi, All when I turn on my head light I notice that a light on the dash stays on it show a time bomb it looks like with a x thru it ... it stays on can't any bulbs out what is that telling me... Thanks for your time
Old Apr 26, 2017 | 01:56 PM
Greg in France's Avatar
This is an intentional feature of the car. The bulb out warning light should go out after about 15 or 20 seconds. It in effect tests the system when the lights are switched on.
If the warning light never goes out, then either there is a failed bulb, or the bulb failure units are malfunctioning.
Old Apr 26, 2017 | 07:32 PM
jkann1's Avatar
Thanks... I found out the bulb on the driver side door is not on when the door is open the rest are.. would that cause it also the bulb on the driver side dash doesn't work either with door open .. but does when the lights are turn on by the interior switch... Thanks for your time
Old Apr 27, 2017 | 12:42 AM
No, the interior lights are not part of the bulb out system. The driver's door courtesy light should illuminate when you open the doors, but not when you use the dashboard switch to turn on the front interior lights.
The fitting just prises out (carefully!) and the bulb inside is a 5watt festoon.
Greg
