pickup coil
Old Jun 11, 2012 | 10:32 PM
  #101
Doug's Avatar
If it helps I found some notes from my Mustang TPS installation. Apparently the TPS terminals were marked A B C
My handrwriten notes say....
Green C 5v power
Yellow A Throttle pot ground
Red B Output to ECM
Of course the "ground" doesn't mean an external chassis ground
<shrug>
Old Jun 12, 2012 | 01:31 AM
  #102
Greg in France's Avatar
Green C 5v power
Red B Output to ECM
<shrug>
I believe, Doug, M90, that 'ground' refers to the return to pin 19, as in my previous post:
"Tpot output non-wiper (ie after the 5v has gone through the resistance, but not including the wiper output) goes to pin 19
CTS output (ie after the 5v has gone through the resistance of the sensor) also goes to pin 19"
Greg
Old Jun 12, 2012 | 07:55 AM
  #103
Doug's Avatar
Right.
"Throttle pot ground signal" is what my schematic says, at pin 19.
Old Jun 17, 2012 | 02:22 PM
  #104
M90power's Avatar
an OEM bournes TPS allowed it to run slightly leaner, but other than that there was no difference. it ran much better with the CTS unplugged.
Old Jun 17, 2012 | 03:43 PM
  #105
M90power's Avatar
My catalytic converters can be eliminated as a suspect, as theyre empty. i had to hack up my exhaust to find out. Xp
SD96XJ6L
Dec 27, 2025 09:58 PM
tlynch
Dec 31, 2020 01:58 PM
Socal_transplant
Oct 1, 2015 01:15 AM
Bcrary3
Sep 27, 2015 12:21 PM
