Possible harness problem with 1995 spark plug coil pack
Old Apr 13, 2023 | 04:51 PM
1955ambassador+'s Avatar
Default Possible harness problem with 1995 spark plug coil pack
I have a 1995a XJS 6 cyl and with new coil packs, the engine still shows spark plug fault on #5 and 6. Is it possible that the wiring harness to those 2 plugs is at fault or can the ECU give the same result? Engine runs buts misses because of the fault. Can ECU be checked and what kind of service would do that ? Nashut55
Old Apr 14, 2023 | 02:31 AM
Welcome to the forums 1955ambassador+,
I've moved your question from General Tech Help to XJS forum. Members here with the same model will be able to help.
Old Apr 14, 2023 | 03:17 AM
Welcome to the Forums.
YES.
The X300, same engine, has issues with that harness where it bends at the rear of the engine, which is aggravated when bent further when changing spark plus or coils.
One wire at a time, rebuild the harness.
Old Apr 14, 2023 | 06:10 AM
Vee's Avatar
Vee
As long as you are sure that you didn't use the plug for #6 on the #5 coil and vice versa, sounds like the wire is the suspect here. (I'm not sure that's easily possible with #5 and #6, #1 and #2 on the other hand....)
You are getting codes p0305 and p0306?
Only other thing to easily check for is corrosion on the pins of the ECU.
Adam J
Apr 28, 2022 08:46 AM
Lagonia
Feb 12, 2022 11:18 PM
e21pilot
Jun 2, 2020 09:08 AM
Rufus T. Firefly
Dec 12, 2019 05:07 PM
9under1roof
Jun 14, 2017 09:08 PM
