Power mods
Old Oct 24, 2018 | 08:52 PM
Ezrider's Avatar
Originally Posted by ronbros
EZ ,have you read post#6 on this thread, i did those mods back in 1994??
trans from 1992 Chevy Van 2500, shift calibrations are much better for performance,last yr for cable operated TV HD units. 10" converter light weight rotation!
rear gears from Jeep 3.73,, custom built LSD ,Dana 44, with Corvette clutch discs!
this not my 1st rodeo thank you.
ron
yup in post #7 i agree with what you said in post #6 not really sure where the hostility is coming from unless it just reads that way. if i were to get a 2nd xjs with a v12 700r4 a looser torque converter and gears would defiantly be one of the first thing i did to it.
i think the only thing i disagreed with you on in this thread was if it would be reasonable to keep detonation under control on a street drivin xjs with boost without first lowering the compression ratio.
not my first rodeo eater iv been building cars and turning wrenches for the majority of my life im not a jag expert by any means but not a novice mechanic ether.
i suppose the o/p has not really said what his goals are what his budget is or what his skill level is so we are kinda all over the map on suggestions and different ways to increase performance.
EZ is that a GM Blower a 4-71 model diesel ?
ron
similar design, both are roots style blowers, its a wieand 144 essentially the same thing as a 142 just with Teflon tipped rotors.
Oct 30, 2020 09:31 AM
Uncle Fishbits
Apr 26, 2019 05:40 PM
Jag4
Sep 9, 2018 07:54 PM
michaelpv1985
Jun 7, 2008 03:09 AM
happilute
Aug 30, 2007 12:00 PM
