power sources in the front of the car
Old Feb 19, 2010 | 08:57 AM
rama1200's Avatar
Default power sources in the front of the car
I want to install a set of fog/driving lights... but I don't want to run cables all the way to the back of the car.... are there any power sources closer to the front?
Old Feb 19, 2010 | 09:25 AM
Doug's Avatar
There are two "+" junction posts on the firewall, one near the brake booster and the other in about the same area on the opposite side. It's been a few years so I can't remember more exactly but you'll see 'em.
Old Feb 19, 2010 | 05:35 PM
Sarc's Avatar
HI Rama
What year is your car ? I thought everything post HE had front fog lamps as standard ? Did you look under the front bumper/fender for any old wiring ? (Maybe a PO removed the front fogs)
Old Feb 19, 2010 | 07:42 PM
Doug's Avatar
On USA-market XJSs foglamps were not factory fitted until around '87-'88 model year.
Old Feb 20, 2010 | 01:59 AM
S.E.R.E.'s Avatar
mine is an 86 and has factory fogs. the wiring should at least be there right?
Old Feb 20, 2010 | 08:44 AM
Doug's Avatar
Yeah, as far as I know the wiring will be there.
Old Feb 20, 2010 | 01:10 PM
rama1200's Avatar
mine is a 94... and I have not seen wires... I see where the lights would screw in... even if there is wires... I don't see a switch in the cabin to turn them on....
Old Feb 20, 2010 | 05:58 PM
Doug's Avatar
Ahhh.....you have a facelift car. Different ball game regarding fog lamps. I can't help, sorry.
Old Feb 20, 2010 | 06:12 PM
Sarc's Avatar
@ Rama
In the cabin, to the left of the steering wheel, underneath the instrument cluster there should be 2 push switches. The left hand one if for front fogs, the right hand one is for rear fogs. This is on a facelifted '92 car. Do you have those switches on your '94?
Old Feb 20, 2010 | 07:29 PM
rama1200's Avatar
Originally Posted by SARC
@ Rama
If I remember.... to the left there are 2 switches... one for the hazard and the other one is not functional... to the right there is the rear fog and window-defog...
Old Feb 20, 2010 | 09:35 PM
Sarc's Avatar
@ Rama
Yes, I just looked at some '94 cars on autotrader and the switches are different from my '92 car. I wish Jaguar would quit moving stuff around !
Anyway, I posted a file link in the other post where you were looking for owners manuals, etc. The circuit diagrams are in there for the fog lights. Have a look at them and you may be able to work out how to wire up a set on a '94 car. But, yes, it looks like you now have 2 challenges..... no switch in the cabin, and no power source. You will also need to run the lamps through a relay.....
BrentGardner
29
Dec 16, 2024 12:13 AM
Paradigm
Jun 15, 2019 05:59 AM
Bernie Posadas
Sep 3, 2015 08:06 PM
souldoubt
Aug 25, 2015 08:15 PM
divingmom
Aug 25, 2015 07:54 PM
