Power steering pump and rack overhaul?
Old Mar 17, 2019 | 08:11 AM
  #41
leo_denmark's Avatar
This looks more like it, but the price is also higher
ebay
Old Mar 17, 2019 | 01:05 PM
  #42
Greg in France's Avatar
Originally Posted by leo_denmark
Yes, that is very good prices. They seems to be without pulley hub, just with a plain axle ? My hub centre seems to be integral with the axle ?
Yes, you have to extract the pulley from the shaft with a puller.
Old Mar 17, 2019 | 01:29 PM
  #43
My pulley is mounted on a hub with 3 small bolts. The hub is part of the original pump, you can see that in the eBay link in my last post.
There is a division line indicating that the hub could be separate from the axle. Just a simple press fit with a woodruff key ?
Old Mar 17, 2019 | 02:00 PM
  #44
Yes, for pulley read hub, sorry!
Old Mar 17, 2019 | 03:53 PM
  #45
warrjon's Avatar
The hub is a press fit and you need a puller that fits in the recess around the hub snout to pull it off. DO NOT use a normal pulley remover it will damage the hub.
There is a 3/8UNC thread inside the shaft to re-install the hub. It is a very tight press fit (no key)
Old Mar 17, 2019 | 11:43 PM
  #46
Dukejag's Avatar
Quick question while talking about power steering.....
I need to top up my power steering - car came with a can of Pentonsin CHF 11S in the boot, but it is green.... stuff in the power steering is red.
What else can I use ?
What do you think the 11S was used for? Convertible roof pump?
1988 V12
Old Mar 18, 2019 | 01:16 AM
  #47
Daim's Avatar
1988 V12
Dexron 2 or Dexron 3. That is what the pump requires...
Old Mar 23, 2019 | 01:47 PM
  #48
Update from Denmark:
I sourced a used pump, which turned out to be non-metric. I then assembled my own pump again (slowly and with high focus on getting it right...) I reused the reservoir part form the spare pump and did the bleeding with wheels of ground. I have just taken the car for a small drive, and it looks like I now have functional PAS again without weird noises.
The tightness will have to be reviewed later. I overfilled the pump and had oil coming out at the filler cap when it got warm...
Dicque
Sep 19, 2015 12:53 PM
sogood
Sep 15, 2015 07:35 AM
1964Daimler
Sep 9, 2015 11:28 AM
MrMellor
Sep 7, 2015 10:22 AM
AL NZ
Sep 4, 2015 08:39 PM
