Power Window
Old Sep 26, 2021 | 01:43 PM
Captain Bob 369's Avatar
Default Power Window
Hi, just replace my 7 year old battery. now my driver power window will not operate. Went to check fuses and all are ok. Owners manual has no listing for a fuse for the windows. Is there one? If so where might it be.
Old Sep 26, 2021 | 01:52 PM
Vee's Avatar
Vee
Not sure what model year you have, but those switches may need a cleaning. I’d check your connection first. It’s not terribly hard to access.
Remove that center console to reveal the ski slope screw and boom!
Old Sep 26, 2021 | 02:32 PM
ptjs1's Avatar
You may read that it's possible to remove the window switches by prising them out from above. DON'T! You will break the retaining tangs and the switches are not available new.
Do it as Vee described and lift the ski slope.
Good luck
Paul
Old Sep 26, 2021 | 02:43 PM
Default Windows
I’m reading a lot of posts about removing the ground cable and touching it to the positive cable to reset the system. Apparently after replacing the battery you have to do a reset. Not sure if that works for my XJS.
Old Sep 26, 2021 | 04:00 PM
ptjs1's Avatar
Bob,
That's the first I've heard about anything needing "resetting" on a 4 litre XJS. I've changed batteries, had them run flat etc etc. Never done a "reset". The only things that may possibly need resetting are the alarm fobs. Certainly things like windows, roof etc have no clever systems that need resetting after power loss.
Paul
Old Sep 26, 2021 | 04:02 PM
Thanks, I’m never sure which models have those style relays.
Old Sep 26, 2021 | 09:38 PM
Vee's Avatar
Vee
I’ll confirm that there is no such reset on an XJS. Anyone who says different is full of it.
Old Sep 28, 2021 | 05:11 PM
92/93 XJS's Avatar
Bob, OBDII cars (your's) have NO computer circuits for power windows. I have lost count of how many window switches I've replaced. Each time a window doesn't work, I do a real easy diag to confirm. Slip a thin, metal blade (putty knife, etc) under the switch housing and swap the connectors between left and right switches. If the offending window works, it's the switch. Quick, easy and definitive.
And, yes, the only thing to "reset" is the alarm module, clock, and radio as Paul mentioned.
Dave in AZ
Old Sep 28, 2021 | 05:24 PM
malc4d's Avatar
But incase you **** up
jaguar xjs window switch | eBay
Old Sep 29, 2021 | 07:48 AM
Vee's Avatar
Vee
Make sure the replacement switch has metal tabs on it. The plastic ones cannot be pressed through the bezel.
I basically bought the cheaper plastic ones and replaced the inners, keeping the original shell, if you will.
Old Sep 29, 2021 | 09:01 AM
ptjs1's Avatar
Bob,
I know that the Workshop Manual says to lift the switch panel from the top, but seriously, Don't!
It's slightly more work but lift the skislope as suggested. You're far less likely to break the switch plinth or the switch itself.
You can also then swap the wires over with the passenger one and test which may confirm if you have a gummed-up switch.
Paul
Old Sep 30, 2021 | 05:14 PM
Thumbs up Window Genii
Thanks everyone who responded. I was away a couple of days and didn't take the lap top. Picked up the car tonight after having all fluids changed and miraculously the window works. Must be a Jaguar Genii.
jsulliva
Sep 12, 2015 01:41 PM
Davebc
Jul 11, 2013 08:15 AM
nickthap
23
Jun 9, 2012 07:31 PM
blackforrestperformance
Nov 9, 2011 03:04 PM
rgggtc
Aug 7, 2011 03:13 PM
