Radio code 1989 XJS AM/FM Cassette
Disconnected my battery then hooked back up. Radio now displays code. Thanks to members on forum I found the code written on the radio case. Tried entering the 5 digit code. On the 5th number entry it beeped but code remained. Is there a trick to entering the code?
No trick that I can think of. But if you enter the code incorrectly three times (I think) you have to wait an hour or so (I think) before the radio will accept the correct code. Something like that; it's been a long time for me, as you can probably tell.
Enter the numbers slower and it should work. See here: https://www.jaguarforums.com/forum/x...t-code-200938/
