Radio stuff
Old Dec 19, 2022 | 11:01 AM
gnmamba's Avatar
Default Radio stuff
Well...my radio went south with no power. Checked the million fuses hiding all over in secret places and all were ok. BUT..I could not find the INLINE fuse!! Disassembled the center console completely and only found a few coins but no fuse.
Anyone run into this ?
94 XJS 6 banger!
Old Dec 19, 2022 | 11:42 AM
Brewtech's Avatar
Yep, radio died. I had to replace mine recently. Same issue as you. I had a spare radio that went into my XJ40 do was able to determine it was the radio and not something else. Get a test light and check for power at the harness, I bet everything is fine. The radio will die in these cars, eventually
Old Dec 19, 2022 | 11:59 AM
gnmamba's Avatar
Default Radio stuff
What a bummer. Radio worked fine when parked and the next morning...eerie silence.
Anyway, I sure would like to find that inline fuse!
Old Dec 19, 2022 | 01:51 PM
jal1234's Avatar
There isn't one in late model cars. The circuit diagram shows one in the noise suppression box in the harness at the back of the radio, but there isn't one in mine. There's a semiconductor in there after the filter choke, but I couldn't make sense of the markings. There is a fuse in the drivers side fuse panel that provides unswitched power to the radio. Should be fuse 4, 5 amp.
Old Dec 19, 2022 | 02:20 PM
gnmamba's Avatar
Default Radio
Thanks jal,
I've checked that one you mentioned and all the others.
When I disassembled the center console I tried to pull the radio out but the cables were too short to fully extend the radio and since everyone said the fuse was in the ctr console I left the radio alone.
Next job....hook up my come a long and rip that radio out!!!
Old Dec 19, 2022 | 02:35 PM
equiprx's Avatar
It was a long time ago but I recall on my 94 V12, the inline fuse on a pigtail directly on the back of the radio.
Old Dec 19, 2022 | 02:49 PM
gnmamba's Avatar
Thanks equiprx,
will check for sure when I get that radio out!
Old Dec 19, 2022 | 06:01 PM
Brewtech's Avatar
Get the radio out and use a test light to check the power feed. No inline fuse to be found.
Old Dec 19, 2022 | 06:54 PM
gnmamba's Avatar
Default Radio
So you're saying there's NO In line fuse?? Prints for my 94 does show one.
Old Dec 19, 2022 | 07:08 PM
jal1234's Avatar
What "print"? Factory diagrams dont show one.
Jon
Old Dec 19, 2022 | 07:24 PM
gnmamba's Avatar
That's funny. Every thread I've read on this forum refers to the inline fuse as displayed on my factory service manual. So I don't know what you have but I'll have to believe mine.
Old Dec 19, 2022 | 09:36 PM
jal1234's Avatar
Take a picture of what diagram you are using. I'm using the 1994 Electrical Guide for the XJS 4.0, Publication Number S-72/94 (4.0L).
If the diagram below is the one you are using from the 5 volume service manual, note that the fuses are shown with a box around them. That means they are in a fuse box. An inline fuse doesn't have the box around it.
Old Dec 19, 2022 | 10:11 PM
gnmamba's Avatar
Default Rafio
Well, since I'm watching the Rams getting snookered right now and since my paperwork is in the shop I may get to it eventually.
I'm certainly not in this forum to bicker with anyone. You have what you consider the correct papers and I have what I consider correct .
Thanks for your time.
Old Dec 26, 2022 | 05:29 PM
Brewtech's Avatar
Well? Whats the update? Did you replace the head unit?
Old Dec 26, 2022 | 05:42 PM
gnmamba's Avatar
Default Radio
Update,;
it's zero degrees in my shop. No progress on the jag. I'm not touching it till temp is above 50!!!! I've turned into a wuss in my old age!!
Old Jan 5, 2023 | 07:53 PM
gnmamba's Avatar
Default Radio stuff
still waiting for some decent temperatures before I mess with the jag!!!
Old Jun 22, 2023 | 10:37 AM
gnmamba's Avatar
finally got that sucker fixed. Radio code works, all my preset stations work, all the speakers work too!!!!
Old Jan 14, 2026 | 06:42 AM
Dave Neuhaus's Avatar
Why would you say that without telling us what the fault was?
Old Jan 14, 2026 | 11:43 AM
cityracer's Avatar
Please share your findings. I'm dealing with this issue now. Did you find the inline fuse?
esipp
Jun 22, 2019 02:22 PM
tmurena
Oct 9, 2017 12:11 AM
Capper
Jul 7, 2016 07:57 PM
whitmcfarlin
Aug 15, 2014 06:57 PM
tcarby
Jul 19, 2010 08:55 PM
