Radius Arm Bushings-Do I Need to Remove Shocks
Old Aug 22, 2016 | 02:32 PM
Vee's Avatar
Vee
Default Radius Arm Bushings-Do I Need to Remove Shocks
I have a 1996 XJS Convertible with AJ16 engine.
Getting through my list of things to do on the car and I wanted to replace the radius arm bushings on the car.
Will I need to remove the rear shocks to this? Does that mean I need to build a spring compressor?
Old Aug 22, 2016 | 02:59 PM
Daim's Avatar
Nope. The radius arms are bolted to the lower wishbone and body. You can undo both ends as are... And even if, the rear doesn't need spring compressors to remove the spring/shock assemblies.
Old Aug 23, 2016 | 01:17 AM
Greg in France's Avatar
You do have to undo the nut on the forward end of the pin that attaches the lower end of the shockers to the lower wishbone, and then knock the pin rearward just enough to let you get at the special bolt on the small, rearward, end of the radius arm, and then to withdraw that bolt to free the radius arm that end. This means the forwardmost shock will dangle in the air at the bottom, but the pin is easily reinserted in the bottom eye of the shocker when you have finished.
Pic attached.
Greg
Attached Thumbnails Radius Arm Bushings-Do I Need to Remove Shocks-img_2765.jpg
Old Aug 23, 2016 | 10:34 AM
Vee's Avatar
Vee
So I can change the rear shocks without compressing the springs? That's great. I had no idea. For some reason I thought I needed to deal with the springs to get to the rear shocks!
Old Aug 23, 2016 | 11:48 AM
Different question, Vee; the answer to which is No. To change the rear shocks you have to remove the springs from them and the shocks from the car. The good news is that each spring is not that strong and is quite easily compressed with a clamp-type compressor each side.
Greg
xjsrookie
Feb 26, 2024 06:53 PM
Terry007
Mar 25, 2016 09:23 PM
garyofnyc
Mar 25, 2016 05:17 PM
NCJagman
Mar 25, 2016 12:58 AM
Jan 9, 2012 11:34 PM
