Re-visiting high idol
Old Jul 16, 2025 | 12:10 PM
BenKenobi's Avatar
The TPS cannot hold the capstan open
Both the Bourne TPS and the red version TPS have a hard stop at the bottom of their rotation though I don't know if the adjustment would be enough to keep the capstan off the stops but they do have physically limited travel.
Old Jul 16, 2025 | 12:19 PM
BradsCat's Avatar
I
The cable moves quite easily in both directions when I push/pull on it. Same for the cruise control cable.
No kinks or tight corners.
As I mentioned I did lubricate both by spraying PB Blaster down the cable housings and then working the cables back and forth numerous times.
No issues detected at the pedal inside the car either.
I really think my issue is with the airbox/butterfly housing connections. Some disassembly will required but its not complicated. Just time consuming.
Yep, its a bit sticky but on the bright side it really cleans out your pours playing golf. Cheers!!
Old Jul 16, 2025 | 12:24 PM
BenKenobi's Avatar
"cleans out your pours playing golf." - yeh right - even in the mid 80's I hide in a refrigerator .... but then I walk around in a T whilst many are wrapped up for the arctic - ya see me wearing a coat stay home ...
Old Jul 17, 2025 | 12:43 AM
Greg in France's Avatar
My defective memory, apologies!
Old Jul 17, 2025 | 02:37 AM
BenKenobi's Avatar
Not necessary to apologise, the tps would need to be pretty badly installed, the Bourne is likely to break - so even though possible in this case not likely I think. I did do an experiment last night and it would cause a gap considerably larger than was indicated here - and I broke a Bourne by letting the capstan return too fast.
Old Aug 7, 2025 | 03:24 PM
BradsCat's Avatar
UPDATE: The high idle vacuum leak on the '86 has been successfully solved. I swapped out the B bank intake manifold with a spare. Two bolt connections partially were stripped, one for the air filter box and the other on the butterfly housing. I then fine tuned the idle down to the 750 range with the AAV adjuster bolt. Bled the brakes, greased up the suspension and off we went. Car runs terrific with the new transmission. No hesitation, no stalls. Power is smooth up and back down under braking. Thanks to all for the input. I m going to declare victory on this issue.
Last two items for this car are: 1) No power to the wiper motor. All the fuse box connectors have power except number #'s 9 & 11 which control the wipers and the fluid pump. This has me stumped. (the wiper motor has been tested and is good). 2) Need to replace the Hi speed fan relay. Need the high volume of air flow to drive comfortably in the summer heat.
This is a very nice car that will soon need a new home.
Old Aug 8, 2025 | 02:21 AM
Brad
It can frequently happen that the fuse live side has power, and sometimes the fuse output side seems to; but the fuse holder spring, or the fuse itself, is just slightly corroded, hardly visible, enough to not transmit current.
Try a new fuse and some deoxit on the copper sprung blades that hold the fuse, and pinch the blades together a bit to improve their grip.
Old Aug 8, 2025 | 06:36 AM
  #28
BradsCat's Avatar
Will do. Thx
SuperChargedXJR
Mar 10, 2025 05:15 AM
yoopas
Aug 11, 2021 01:07 AM
AC0FC
Oct 15, 2019 11:42 PM
Tijoe
Sep 27, 2018 09:57 AM
Robert Walker
Sep 25, 2012 12:19 PM
