Really Confused!!
Old Feb 11, 2010 | 09:44 PM
jfrog's Avatar
Default Really Confused!!
Hey everyone,
This thread is kind of an attachment to another one I have. Sorry for the repeat but I really need some help. I am still having a lot of trouble getting the fuel pump to run on my 84. I am stuck! Anyway, the pump is new and the relays are new. I had one diagnosis being the ground circuit for the relays in the ECU being bad. The only problem is, I have no idea how to fix this. Does anyone know how to fix this? Does anyone else think there maybe something else that might be wrong?
Any help would be great! Thank in advance!
Keith
Old Feb 11, 2010 | 11:14 PM
Doug's Avatar
AJ6 Engineering in Britain repairs the ECUs. They're on the www. There might be others, I'm not sure.
It would be easy to rewire the circuit so the pump runs whenever the key is on. Others have done so. There is a safety aspect involved, though. If there was an accident or fire fuel would keep pumping even if the engine isn't running
Old Feb 12, 2010 | 02:25 AM
Hi guys, Doug, not tried this on a Jag but in my old V8 Off Road Landies and Rangies I used to fit a prominent battery cutout switch to kill the electrics in the event of a compromising situation.
This by default also killed the fuel pump.
Old Feb 12, 2010 | 07:45 AM
Doug's Avatar
The Jags do have an inertia switch for that purpose but I'm not sure what the triggering parameters are. We'd have to crash the car to find out :-)
I wouldn't wring my hands with worry or have any sleepless nights because of it, but I can think of several scenarios where you wouldn't want the fuel pump to run with key on, engine off.
Old Feb 12, 2010 | 09:05 AM
I'll try to dig out the pics of my old spares car. It was rolled approx 5 times with 4 adults onboard.
Not only did the inertia switch not go off, but the air bags also did not fire!
No injuries to anyone BTW, but the car, flat would be an understatement.
I agree, about not to worry too much, but if you hard wire the fuel pump then at least add an on/off switch somewhere.
Jfrog, you refer to this being a continuation of a previous thread, to avoid going around in circles, with try XYZ, when you have already tried XYZ, please will you post a link to your previous thread here.
Cheers,
Old Feb 12, 2010 | 10:17 AM
jfrog's Avatar
Great! Thanks guys! So, how would I go about re-wiring the fuel pump? Would it be cheaper to do this compared to having my ECU repaired?
Sorry about that Translator, here is the link to my other thread: https://www.jaguarforums.com/forum/s...ad.php?t=28084
Thanks again guys!
Keith
Old Feb 12, 2010 | 11:11 PM
Doug's Avatar
Thanks again guys!
Keith
As I recall....others will chime in....it's simply a matter of taking the orange wire at the f/pump relay and attaching it to a permanent ground
Old Feb 14, 2010 | 12:32 PM
jfrog's Avatar
So, I see that the orange wire is feeding into one of the relays. Where exactly is the orange wire coming from? Do I just cut the orange wire at the bottom of the relay and ground it out in the trunk?
Thanks,
Keith
Old Feb 14, 2010 | 07:37 PM
Doug's Avatar
Thanks,
Keith
It comes from the ECU, which send a ground signal to energize the relay. Yes, just clip the orange wire and run it to a good ground
Old Feb 15, 2010 | 01:34 PM
jfrog's Avatar
I went ahead and clipped the orange wire from the relay and ran it to a good ground. I still have no power to the fuel pump. Any other suggestions??
Thanks,
Keith
Goncalo Proenca
Dec 9, 2023 04:00 PM
baskervillema
Oct 1, 2015 06:43 PM
mrplow58
Sep 30, 2015 08:56 AM
Zarro
Sep 24, 2015 08:34 PM
