Rear axel case seal
Old Oct 3, 2021 | 01:51 PM
Captain Bob 369's Avatar
Unhappy Rear axel case seal
Just had all the fluids changed and shop said the left side rear axel where it enters the rear housing is wet. Probably has a leak. Question how does this outer seal get replaced? Do we need to drop the whole aft section or is it an external seal that can be replaced over the axel? 1995 XJS 4.0 auto.
Old Oct 6, 2021 | 02:09 AM
baxtor's Avatar
1995 so outboard brakes. Drive shaft needs to be separated at inner universal joint. Output shaft can then be removed after undoing the 5 bolts retaining the housing.
The output shaft assembly needs to be disassembled in order to replace the seal in the bearing housing.
Not a particularly difficult job.
dgutzke
Dec 1, 2017 01:31 PM
bocagq45
Oct 29, 2014 04:41 PM
sambella
Oct 1, 2014 03:02 PM
magnoliav12
Feb 22, 2013 06:06 PM
Kassaq
Aug 15, 2011 03:23 AM
