Rear Wheel Hub cover
Old Mar 6, 2020 | 09:54 PM
Mikekeay's Avatar
Default Rear Wheel Hub cover
I may have exact part terminology wrong but I’ll call it the “constant velocity boot”. I’ve recently returned from a long trip approx 1200 miles as trip meter. Whilst on our journey a minor banging noise was heard from rear left of car, my first thoughts were that the rear left silencer had become come loose, it’s was particularly worse when turning a right corner or bend putting pressure on the left hand suspension.
Back home now still very concerned I jacked up and removed left rear wheel. Immediately I noticed what is to me a loose “boot” cover from back of the wheel hub held on by a jubilee clip on the driveshaft from the diff., obviously loose. I’ve pushed back the loose “boot” re tightened the jubilee clip and now all is tight and subsequent road test all is quiet as it should be. I’m relatively new to the XJ-S so forgive me for my ignorance, am I to just put this down to a maintenance matter, the jubilee clip is in good Nick, tightened up no obvious fluid leakage. Any opinions much appreciated.
mike
Old Mar 6, 2020 | 10:54 PM
Doug's Avatar
They're simply tin U-joint covers
https://parts.jaguarlandroverclassic.../brand/jaguar/
Some guys take 'em off entirely and toss 'em over the hedge
Old Mar 7, 2020 | 09:12 AM
Dleit53's Avatar
You fixed it! There is a hole in the cover that allows access to a grease fitting on the U-joint. You have to position the cover so the opening is aligned with the grease fitting.
tberg
Oct 3, 2014 05:55 PM
supraman
May 1, 2011 10:24 AM
RJag
Nov 4, 2009 10:48 PM
IdahoXTypeOwner
Feb 22, 2008 06:43 PM
