recommended oil for the steering pump
Old Oct 2, 2018 | 08:00 AM
Shahar Alon's Avatar
Default recommended oil for the steering pump
what is the recommended oil for the steering pump
(1988 5.3l xjs)?
Old Oct 2, 2018 | 09:19 AM
bladerunner919's Avatar
Automatic transmission/power steering fluid.
Old Oct 2, 2018 | 01:00 PM
Crackerbuzz's Avatar
Yip that's the one - Manual says Dexron 2D or Type G
Old Oct 2, 2018 | 01:38 PM
sidescrollin's Avatar
It's easiest to just use the same fluid you stick in the trans, less stuff to keep in stock, also a little easier to spot on the ground for leaks.
Old Oct 6, 2018 | 01:50 PM
shtekler's Avatar
I have Jaguar XJ6 1990 Sovereign vin# 595137 I use at the moment the green mineral oil but has leak problems (3 racks were replaced) is it better just to replaced the oil to the red one?
Old Oct 7, 2018 | 12:26 PM
JagCad's Avatar
I've used ATF in most of my critters, including my 83 XJ wuzza 6.
No issues at all
Carl
Old Oct 7, 2018 | 10:13 PM
Doug's Avatar
Best to ask in the "XJ40" section.
Those/your car has a hydro-assist system for the steering, brakes, and suspension that is quite different than an ordinary pump system. I think the green hydraulic fluid is quite specific to that application and shouldn't be sunstituted
Old Oct 7, 2018 | 10:15 PM
Doug's Avatar
Just to be clear, power steering fluid and automatic transmission fluid are two different things.
Over the years many power steering systems have used automatic transmission fluid. However, you'd never want to use power steering fluid in your transmission
Diddion
Mar 21, 2023 09:16 PM
Mad Matt
Dec 29, 2014 05:22 PM
Safari
Oct 12, 2014 03:24 PM
weisberg
Mar 4, 2014 12:19 AM
desertchimera
Feb 5, 2014 12:54 PM
