Removal of smog equipment
Old May 21, 2019 | 01:43 PM
84jagxjs's Avatar
Default Removal of smog equipment
In other threads members mention a kit to “replace the plugs” when the smog equipment is removed and an idler pulley for the belts. Where did you get the factory style plug kit I would use when i removed the smog system. Also , who did you order the idler pully from? I would like to clean up my engine compartment too.
Old May 21, 2019 | 01:49 PM
EcbJag's Avatar
The idler pulley will likely have to be sourced from the UK. Contact Simply Performance.
Old May 21, 2019 | 02:53 PM
VancouverXJ6's Avatar
Bando 3430 belt goes from AC to crank pulley apparently, thus eliminating the need for a tensioner? As for the plugs I tapped them where the little pipes went in and inserted these set screws with jbweld etc, not show car perfect but it worked. You can buy a nice set where its all machined perfectly but they were way over priced.
Old May 21, 2019 | 08:00 PM
BradsCat's Avatar
I bought the plugs from someplace in England unfortunately I can't remember who but there has to be someone on here that can give you the contact info for a shop. es they were a bit pricey but it's the look I wanted so bit the bullet for the extra money.
Old May 22, 2019 | 01:31 AM
Greg in France's Avatar
https://www.rushtonengineering.co.uk/our-products/
Old May 22, 2019 | 07:52 AM
Doug's Avatar
FWIW, I simply tapped the holes and installed 'grub screws' from the local hardware store. I think I spent about $3.00
Old May 22, 2019 | 08:15 AM
bladerunner919's Avatar
I tapped the holes and fitted button-head screws. The Ł110 cost of the caps is way more than you need to spend.
Old May 23, 2019 | 05:47 AM
84jagxjs's Avatar
Default thank you
thank you , this looks like the way that I will go. I just now need to see source the pulley and figure out what I can and cant take off.
Old May 23, 2019 | 05:50 AM
84jagxjs's Avatar
Default Belt
I haven't seen that. I am guessing that "Bando 3430" is the size of the belt? this would certainly make it easier.
Gus
Jul 27, 2015 03:35 PM
Staatsof
Jul 20, 2010 07:05 AM
Jaguardoc504
Jan 5, 2010 12:00 PM
Jaguar6286
Detailing / Car care
Dec 19, 2008 06:34 PM
slickman
Jun 5, 2008 04:30 PM
