Replacement TPS 1996 XJS 4.0L
Old Dec 31, 2018 | 10:31 AM
Softball60's Avatar
Default Replacement TPS 1996 XJS 4.0L
Does anyone know of a less expensive Ford TPS control for the 1996 XJS. The Jag unit is a couple hundred. I have seen other ford products that look similar....but do they fit or work?
Thanks as always
Softball60/Paul
Old Dec 31, 2018 | 11:35 AM
cubist's Avatar
Hi There,
As yours would be a AJ series engine, fully manufactured by Jaguar, I would say it's highly unlikely that a Ford TPS would fit without at least some modification. Even then it may be dubious whether it would communicate properly with the ECU. I stand to be corrected on this one but you would be better off in my opinion going with a genuine Jag product.
Cheers,
Cubist
Old Jan 1, 2019 | 10:19 AM
Vee's Avatar
Vee
Nope. There isn't. I've spent many hours researching. It ended up being the solution to an overfuelling problem. The TPS tested fine, but a new one cleared my issue right up!
Bite the bullet.
Old Jan 1, 2019 | 11:28 AM
Softball60's Avatar
Bite the bullet.
Vee,
Does the TPS for this Model yr XJS also fit other Jaguar Models?
I know do 5 or 6 jags sitting in a pick your part yard. Might be worth getting a couple if they work
Softball60/Paul
Old Jan 1, 2019 | 12:17 PM
Vee's Avatar
Vee
Oddly enough, I had inherited a used and untested spare from a low mileage parts car. Seemed to make no difference between the two, which I found odd, and ended up throwing other parts at the problem, until I circled back (when all else essentially failed), bought a new one and poof! problem disappeared.
I think these sensors might go with age. Any part you pull will be at least 23 years old. It was time.
Old Jan 2, 2019 | 11:45 AM
Jagboi64's Avatar
Originally Posted by cubist
Hi There,
The original part that came from the Jaguar factory has the Ford oval on the TPS, thus the OP's question of what Ford it was used on. Similarly, things like the air injection check valve on an XJR has the Chrysler pentastar on it, and for normally aspirated engines the valve is made by General Motors.
Old Jan 2, 2019 | 12:50 PM
Softball60's Avatar
Thanks Jagboi64,
That is what I thought!! That is why I asked the question.
Now.
Does anyone have an idea of what vehicle it might be used on??
Softball60/Paul
Old Jan 2, 2019 | 01:55 PM
Jagboi64's Avatar
Sure looks like a Sierra 2.9
https://www.ebay.co.uk/itm/THROTTLE-...tn~d:rk:3:pf:0
I have not checked the cross reference numbers on this one: https://www.ebay.co.uk/itm/Kerr-Nels...mzV:rk:14:pf:0
Old Jan 3, 2019 | 10:41 AM
katar83's Avatar
I definitely saw a pic of someone using a TPS from another car, unfortunately cant remember what it was and cant seem to find it now. That sierra TPS looks exactly the same as Jag unit though and looks cheap enough to give it a try. TPS is just a potentiometer so anything with a 0-5V range and similar pinout and curve should work fine in there(Ford Puma one possibly), just a matter of actually mounting it to the TB.
V12 TPS can be easily replaced with a TPS from a Mustang, its basically the same TPS in a slight different body so cant see why it would be different with AJ16.
Old Jan 3, 2019 | 03:21 PM
Softball60's Avatar
Thanks,
Sure looks like we are on the way to solving my original question.
Someone out there must know the answer!!
Softball60/Paul
Old Jan 8, 2019 | 11:51 AM
Softball60's Avatar
Is there anyone over in Europe who have any ideas regarding my replacement?
Softball60/Paul
Old Jan 16, 2019 | 08:27 PM
JigJag's Avatar
86-93 Ford Mustang 4cyl. Should be able to find one somewhere in Europe, or you could order one online.
IIRC they start at around .36 v and too out around 4.7 v. Apparently works adequately despite the differences.
Old Jan 17, 2019 | 06:31 AM
Vee's Avatar
Vee
Any idea on how much someone would save using this Mustang part over the OEM?
Old Jan 17, 2019 | 06:41 AM
Softball60's Avatar
If it is like the one for the Ford Sierra (Europe model) as mentioned in earlier thread we are talking Hugh difference.
The TPS for the 1996 XJS is ~ $500 or slightly more. The one for the Sierra was like $50-$60.
Softball60/Paul
Old Jan 17, 2019 | 11:07 AM
Softball60's Avatar
Any idea of the part number? I have been searching but can’t quite get to it. I see parts that look similar but want to be sure.
Also, any equivalent US versions
Softball60/Paul
Old Jan 18, 2019 | 09:23 AM
Doug's Avatar
The Mustang TPS is about $20-35 depending where you shop. Add another $10 or so to get the matching connector, if desired.
I used one for years on my '88 XJS V12; worked fine. Minor mods needed for fitment. A couple hours of easy fiddling on a Saturday.
More recently I had one on my present V12 and worked well but it failed after about a year. Tried another but couldn't get the closed voltage low enough; went another direction after that.
I've gathered, perhaps incorrectly, that the Fords of the era happy with about .5v at closed throttle and the TPSs are designed for that. It might be luck of the draw...production variances.... to find a Ford TPS that'll yield the .32-.36v that the older V12s need.
I dunno what voltage the AJ16 needs to see at closed throttle
steveinfrance
Dec 31, 2020 06:15 AM
gwagner
Jun 1, 2016 08:37 PM
curtizb
Nov 5, 2015 12:36 PM
sogood
Oct 20, 2014 06:04 AM
