replacing instrument panel bulbs
Old Jun 12, 2012 | 01:07 PM
JagVilly's Avatar
Default replacing instrument panel bulbs
Ok, so the combination of dim lights on the left of the cluster and the completely dark area of the right of the cluster drove me a bit mad so i decided to grab a screwdriver and got at it.
I pulled out the instrument cluster and began pulling bulbs from the backside to see what was causing the issue. I noticed one of the bulbs had a broken filament so I went to the store and just replaced all five so as to not worry about different life spans on the bulbs.
Dropped it back in and nothing! Same issue. Guess I should check the fuse next? Where is the fuse for the cluster located?
Old Jun 13, 2012 | 09:40 AM
Greg in France's Avatar
The problem is that the bulbs are only 2 or 3 watt, and they have very dark green coloured shades in front of them . These aforesaid shades discolour badly over time and go black with heat from the bulbs.
The shades are best removed (requires a bit more dis-assembly of the unit) and 5 watt push-ins used instead of the 2 or 3 watt ones. Then the light intensity rheostat has a proper purpose and night driving is transformed.
Greg
99xk8guy
Sep 29, 2025 10:51 PM
Forcedair1
Sep 8, 2025 01:57 PM
afterburner1
Dec 16, 2015 12:12 AM
obwoodie
Sep 3, 2015 07:45 PM
KarimPA
Sep 3, 2015 07:32 PM
