Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
Old Sep 15, 2021 | 03:58 PM
  #1061
Rescue119's Avatar
Got the rhs tb on and the rear parts connected to the intake manifold
I almost forgot about the tb return springs til I saw one on the cowling lol. Put one on and was fine but other one seemed streched. Probably from when I lifted the whole assembly off and forgot about it.
So ordered 2 replacement ones from sng as well as some rubber elbows i needed.
Still looking for an answer to my question I posted.
Can I just replace this pipe connection with a hose? Circled in black.
Old Sep 16, 2021 | 06:14 PM
  #1062
Rescue119's Avatar
Why I wait for some paint to dry I started into this.
Old Sep 17, 2021 | 01:41 AM
  #1063
Greg in France's Avatar
Yes, the swaged connection can be replaced with a new hose and a clip.
Old Sep 17, 2021 | 03:22 PM
  #1064
Rescue119's Avatar
Got the fuel injectors and everything apart.
Will start cleaning them all tomorrow if I'm not hungover from going to a blue rodeo concert tonight lol.
Old Sep 19, 2021 | 04:31 PM
  #1065
Rescue119's Avatar
Little more progress on the injectors.
The main bodies are almost ready for new hardware. Still need to finish cleaning the metal plate holder and the metal ring that goes around them
Old Sep 29, 2021 | 12:07 PM
  #1066
Rescue119's Avatar
Off from work next few days but one of them is the misses bday so no work that day lol.
Injectors almost done.
Old Oct 1, 2021 | 03:23 PM
  #1067
Rescue119's Avatar
Injectors installed and rail painted
Old Oct 2, 2021 | 01:29 AM
  #1068
Really nice job, Rescue.
Old Oct 2, 2021 | 09:35 AM
  #1069
Rescue119's Avatar
thanks
Rails on.
Old Oct 4, 2021 | 11:10 AM
  #1070
Mguar's Avatar
These three options are not the whole story. The XJS was originally launched with the 5.3 litre fuel injection engine. It had the so-called "flat-head" cylinder head. This same engine was in the E Type and early models of the saloon, but with carburettors. The XJS was the first jaguar to have a fuel injected V12. It was powerful but used very large amounts of fuel, especially in traffic.
In about 1982/83 this same basic engine was produced with a new cylinder head designed by a Swiss engine combustion specialist called Michael May and called the HE cylinder head by Jaguar, HE meaning High Efficiency. This cylinder head gave a bit more power, but very much better part-throttle fuel economy. This is what is referred to as the HE engine.
Slightly confusingly, this 1982/3 relaunched version of the XJS was called the XJS HE. When launched, the XJS with the HE engine was fitted with catalytic converters for certain markets, but not for others. The USA cars for example had catalysts, but UK cars did not. So some HE cars had catalytic converters and some did not.
From later on, about 1989 or 1990 I think, all HE engined XJSs regardless of markets had catalysts.
Sometime in the late 1980s Jaguar stopped using the HE description on the V12 XJS and just called it the XJS V12. But the engine in the car remained the same HE version.
From about 1992 or maybe a year later (do not know the actual date), the 5.3 litre HE engine was expanded in capacity to 6.0 litres, but the cylinder head design remained the same apart from some mods to give the desired combustion ratio. So 6 litre engined XJSs have an HE-headed engine but just a bit larger in capacity.
minor corrections . The HE was introduced in 1981 also the US horsepower was the same as the earlier pre HE. The ignition timing went from 38 degree down to 17 degrees to keep from preignition or detonation on gasoline available at the pump. With racing gas 110 octane time can be advanced to 38 degrees and an increase in power is the result.
The main reason for the HE head was to conform to upcoming California smog regulations about to be introduced. Since more than 50% of Jaguar sales are to America loss of the US market would have been the death blow to the then struggling Jaguar. ( by the early 1980’s Jaguar was losing over £50 million pounds a year.
Higher compression naturally increases fuel mileage while retarded timing hurts it. But much of the fuel mileage gains was due to other improvements such has taller gear ratio. (From 3.07-2.88) introduction of the GM turbo 400 in 1978, revised fuel injection from the Bosch system to the Lucas system.
Race cars always used the earlier pre HE heads due to better flow. The HE heads limit flow to the point that going beyond 450 hp is extremely difficult. While the Pre HE heads have made as much as 894 hp.
Old Oct 4, 2021 | 11:33 AM
  #1071
Rescue119's Avatar
So if I run 110 I can increase the timing? Lol.
Old Oct 5, 2021 | 04:49 PM
  #1072
Rescue119's Avatar
Hey Greg, I'm thinking either getting my alt rewound to 110-20 amp or replacing it (will also be going into the air pump location)
What ya think?
Old Oct 6, 2021 | 12:23 AM
  #1073
What ya think?
115 to 120 alt a GREAT idea, I went through alternators all the time until I upgraded to one, everything worked better with it, instruments, voltage levels, everything. The 75 amp OEM one is just not powerful enough.
Old Oct 6, 2021 | 05:58 AM
  #1074
Rescue119's Avatar
There's a local company that rebuilds. I'm gonna give them a call and see if they can rewind using the orginal housing and see how much it will cost. I know I can get that land river one from th UK but I'm looking at around 300cdn. I'll see if they can do better before buying a new one. I know I'll need to redo the cables as well. Which I was planning on.
It's Thanksgiving weekend coming up in Canada so I hope I can get some more work done
Old Oct 8, 2021 | 02:32 PM
  #1075
Rescue119's Avatar
new fuel hoses run. Only part not connected is the end going to the fuel cooler. I'll wait to that's back in place before I cut the remaining hose to length
Old Oct 8, 2021 | 02:34 PM
  #1076
Rescue119's Avatar
Do I really need this one? I already deleted the other on lol.
LHS. Just realized it's gonna cover my new stickers lol
Old Oct 8, 2021 | 02:36 PM
  #1077
Thorsen's Avatar
The regulator on the B banl/left hand side of the engine is needed.
Old Oct 8, 2021 | 02:39 PM
  #1078
Rescue119's Avatar
ugh I know I kept it for a reason lol
Old Oct 8, 2021 | 02:58 PM
  #1079
Otherwise no fuel pressure!
Old Oct 8, 2021 | 03:04 PM
  #1080
Rescue119's Avatar
But the sticker! For the love of God think of the stickers!
I shouldn't have started drinking at noon today.
Happy Thanksgiving!
