Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
Old Jun 20, 2022 | 12:49 AM
  #1241
Greg in France's Avatar
Originally Posted by Rescue119
So tapped the line from the compressor relay. I hope lol.
Just need to get the expansion painted and mounted then add coolant. About it.
Oh and put in a new fuel filter. I'll refresh the rest of the fuel system at a later date.
Rescue, Be CAREFUL.
If you have a Delainair III unit then ignore this post. On my car (Delanair II) the compressor is actuated by 12 volts coming down a green wire that runs down the centre of the V. I have no idea where it originates, to my shame!, but it is not in the engine bay.
You could always tap off the feed to the compressor by the compressor itself.
Old Jun 20, 2022 | 05:02 AM
  #1242
Rescue119's Avatar
Rescue, Be CAREFUL.
Edited: Yes i have the III
The green/white wire goes into the green wire further down the line according to the scematics.
my wiring is more like an 89/90 then an 88. Not.sure if it's because of it being an North American / Canadian model.
Old Jun 21, 2022 | 01:37 PM
  #1243
Rescue119's Avatar
So I got the header tank in.
So I have 3 spouts left to connect.
I believe this piece (with pipe in middle) goes from the bottom of the expansion tank to the Tee that's in the cross water pipe. Seems to be right but want to confirm
Now for my last one does this connect to this via a hose?
Don't mind the wiring everywhere I'm not tidying it up still she runs lol
Old Jun 21, 2022 | 04:45 PM
  #1244
Rescue119's Avatar
Figured it all out. I was right.
Time to pick up some coolant
Old Jun 21, 2022 | 07:09 PM
  #1245
Rescue119's Avatar
thoughts?
Old Jun 22, 2022 | 02:33 AM
  #1246
Utter waste f time and money, introduces more points for failure.
Old Jun 22, 2022 | 04:37 AM
  #1247
JayJagJay's Avatar
thoughts?
Yeah,,,, I wouldn't be messing around with one of those. I can see a few problems, 1 or 2 BIG ones... Especially in a car that hasn't had weeks and months of coolant circulation after a looooong sit up...
Old Jun 22, 2022 | 04:48 AM
  #1248
jal1234's Avatar
Not so quick on dismissing them. Pull this crap out of my two Ganos filters yesterday. This was after a flush, new water pump, recored radiator, and a new coolant tank. Black flakes apoear to be paint from God knows where. There was also sand, some as large as small pebbles.
Old Jun 22, 2022 | 06:10 AM
  #1249
Rescue119's Avatar
Where did you have it installed upper rad hose?
Just curious.
Old Jun 22, 2022 | 06:17 AM
  #1250
Rescue119's Avatar
So the jags ready to be turned key once I fill it up with coolant.
Probably attempt it on Saturday.
I've plugged all the vacuums that I found.
There are those 2 vacuum controlled sensors. (One on the rhs far back, purple, 3 nipples all broke off and then the other one is on the lhs behind the efi temperature sender, 2 nipples broken off)
I cant put caps on them obviously. If I leave them as is will it affect anything or should I put some silicone or jb weld on them to plug the holes? Or is there blanks i can buy and remove them and put the blanks?
Old Jun 22, 2022 | 08:44 AM
  #1251
jal1234's Avatar
Just curious.
Both upper radiator hoses. Have another in the inlet line to the heater core, before the heater valve.
Oh, and that was after about 1000 miles after doing the service work. I'd also changed all of the coolant hoses.
Jon
Old Jun 22, 2022 | 09:25 AM
  #1252
Cap the vac spigots, rther than blovking them.
Is yours a LUCAS igniiton or a Marelli? If Lucas, you need a vac line to the dizzy vac capsule from the manifold.
Old Jun 22, 2022 | 01:41 PM
  #1253
Rescue119's Avatar
I cant cap the ones on those 2 sensors as the are broken st the base.
Lucas and yes I run a vac line to the manifold as required.
I could put a screw in then cap it lol
Old Jun 22, 2022 | 03:25 PM
  #1254
garethashenden's Avatar
Be prepared for filling the car with coolant to be a long slow process. It took me a few times to get it right. Don't be tempted to put coolant in the cross pipe until you're really sure its full. Fill the header tank, wait for it to settle, top it off, wait, top it off again, repeat and repeat and repeat.
Old Jun 22, 2022 | 07:08 PM
  #1255
Rescue119's Avatar
I use the process Grant uses. But yes it's super slow. 20L ugh. I did buy it today at least lol.
Old Jun 22, 2022 | 07:17 PM
  #1256
jal1234's Avatar
Get the nose of the car as far up in the air as you can. You'll get air to bubble out a lot faster. It makes a huge difference.
Jon
Old Jun 23, 2022 | 12:24 AM
  #1257
Just pinch off the line to them then.
Old Jun 23, 2022 | 04:56 AM
  #1258
Rescue119's Avatar
I dont think you are understanding that there's no lines to them because I got rid of all the emissions stuff.
this one the vacuum control valve #12
And #7 thermal valve.
Both of these have no hoses going to them no due to eliminating the emissions stuff.
And i cant cap them because all the little spigets broke off when i removed the hoses (really brittle if anyone is going to remove them in the futures) but the holes in them are open at the moment.
Old Jun 23, 2022 | 06:18 AM
  #1259
From the diagram these look like they are screwed into the water manifold. Are the things just sensors that open and close a vac pipe, or will the coolant leak through them? Either way, just block them somehow, anyhow, off say I. they do not exist on UK models AFAIK.
Old Jun 23, 2022 | 06:41 AM
  #1260
Rescue119's Avatar
Correct On the water pipe. All emissions NA garbage
