Rescue's Official Build Thread - 88 XJS V12 Oct 12 2019
Old Jun 23, 2022 | 04:46 PM
  #1261
Rescue119's Avatar
Got my 3rds today... Sgt....celebrated by drinking
from my Grandfather's sgts mess mug from when he was in England
Old Jun 23, 2022 | 06:16 PM
  #1262
Rescue119's Avatar
So I removed those 2 sensors. The holes don't go right through. So I trimed the ports off and smoothed the top with jb weld. I'll smooth them out tomorrow and reinsert them
Old Jun 24, 2022 | 12:41 AM
  #1263
Greg in France's Avatar
Good for you Rescue. Congratulations. Everyone knows that the NCOs run the armed forces!
Old Jun 24, 2022 | 07:22 PM
  #1264
JayJagJay's Avatar
Originally Posted by jal1234
Not so quick on dismissing them. Pull this crap out of my two Ganos filters yesterday. This was after a flush, new water pump, recored radiator, and a new coolant tank. Black flakes apoear to be paint from God knows where. There was also sand, some as large as small pebbles.
Well damn Man... That's pretty undeniable...
Question: After you run it with the filter, do/would you recommend removing the filter (mission complete) or leaving it for the long term?
Old Jun 24, 2022 | 08:42 PM
  #1265
jal1234's Avatar
Question: After you run it with the filter, do/would you recommend removing the (mission complete) or leaving it for the long term?
I'm going to leave them. According to some, casting sand comes out of the engine "forever". I'll check them periodically. Who knows what else I'll catch?!
Jon
Old Jun 26, 2022 | 03:47 PM
  #1266
Rescue119's Avatar
Put the 2 air breathers back on and just released I never ordered new air filters lol.
Also on the lhs I need to plug 2 holes due to removing the smog pump.
Still haven't put in the coolant yet.
Hoping to roll it out of the garage this week.
Old Jun 26, 2022 | 08:26 PM
  #1267
Rescue119's Avatar
So I started refilling the coolant following grants procedure, as I have done before seen here with left side jacked up...
...after about 1 hr of slowly filling it up I'm around 20L and I here coolant dripping, it's coming out of the air bleed hole first.... ok.... I cap it... put just a little in and I can here it going into the expansion tank.... that's when I here coolant dripping again.
I guess my patch job of the crack at the bottom failed...
So I removed the expansion tank and have it sitting in the pan draining. Will access tomorrow.
But I did notice that there was a lot of fluid in the expansion tank more then I thought when i removed it so was wondering why it didn't come out of there first instead of the bleed hole?
More to follow tomorrow
Old Jun 27, 2022 | 11:55 AM
  #1268
Rescue119's Avatar
First day of vacation ya!
So started the repair on the expansion tank. Will know tomorrow if I did a better job.
Changed out the fuel filter...high on fumes now lol j/k. Was easy.
Started cleaning up the garage and getting all the parts i have scattered about together.
Hopefully get it off the stands tomorrow and out if the garage.
Old Jun 27, 2022 | 12:00 PM
  #1269
BenKenobi's Avatar
Sure wish I was as close to getting mine back on it's feet - careful with the cleaning up - generally means you'll be making a mess again if sod is around with the rule book. Got to admire the persistence and focus.
Old Jun 27, 2022 | 01:27 PM
  #1270
Rescue119's Avatar
sod? Lol
No mess until I get to me new house and new 3 car garage.
I'm gonna have to buy some garage mats to pair the xjs on. Cause who knows when it will leak again lol
Old Jun 27, 2022 | 01:33 PM
  #1271
BenKenobi's Avatar
Perhaps 'sod' doesn't make the transatlantic journey ...
We say Sod's Law or Murphy's Law - it is a way of saying that whatever you think, reality will have something else planned.
For me it is the point where I pack the tools away, clean up only to go get them out again when I spot what I missed despite all those check's, rechecks - I mean what could go wrong - well Sod and Murphy pretty much conclude 'everything' ... set the expectation low that way the level of disappointment is reduced.
Old Jun 27, 2022 | 01:59 PM
  #1272
Rescue119's Avatar
Yep i hear that. Always happens
Old Jun 27, 2022 | 06:48 PM
  #1273
Rescue119's Avatar
Got the expansion tank mounted again. Will continue filling up with coolant tomorrow.
Fixed the truck lid latch.
Also took the ant out. It never went all the way down (bottom section). So looked inside. Extended it by hand using the inner gears, the bottom section came out more and noticed a slight bend in it. So bent it back slightly. Also took 2000grit to all the sections to polish them up, then rubbed lubrication oil along the whole section. Seems to be better but won't know till I hook power up to it. Meh was gonna gut the whole system anyways down the road.
Old Jun 28, 2022 | 01:44 AM
  #1274
Rescue
Translation please!
Old Jun 28, 2022 | 05:59 AM
  #1275
JayJagJay's Avatar
Rescue
Translation please!
Auto antenna I think...
Old Jun 28, 2022 | 06:07 AM
  #1276
Thanks, JJJ, makes sense now!
Old Jun 28, 2022 | 06:14 AM
  #1277
Rescue119's Avatar
Haha yes the radio antenna in the trunk (boot for you across the pond)
Old Jun 28, 2022 | 10:36 AM
  #1278
Rescue119's Avatar
ready to come off the ramps. Just need someone to help push as i dint want to start it in the garage in case i ****ed up big time.
Good news i hooked up the battery and didn't see any leaks or anything.
the radio antenna now goes up and down like intended so that's a win.
So while I'm waiting for help I do have a wiring concern.
So when I turn this switch on
The aux fan comes on. that 12" fan is loud and strong fyi. Go spal!
thoughts as I was trying to have it only come on when the compressor comes on. Or by activating that switch should the compressor be tripped?
Old Jun 28, 2022 | 12:05 PM
  #1279
Rescue119's Avatar
So got it outside of garage.
Wouldn't start. Then I realized that it's a year old gas in it. So just put fresh 91 oct gas with fuel stabilizer, 105 octane boost.
Waiting for the battery to charge back up.
It almost started. I can feel the fuel Ines are charged. Nothing leaking so far.
I'll report back in an hr or so.
Time to tidy up my garage while I wait
Old Jun 28, 2022 | 02:57 PM
  #1280
Rescue119's Avatar
didnt want to start. I posted in the got a v12 HE that wont start thread. I am thinking TPS as I did the test and didnt here the injectors clicking (anyone got a sound clip on what it should sound like?)
