Rotor Hub Seal
Old Nov 21, 2019 | 09:25 PM
lasstss's Avatar
Default Rotor Hub Seal
Hey folks need help.
I went to put new seals on the front hubs and cant get them in. CBC2858 / 0523413
far too big to fit the hub and extremely tight on the spindle?
Spindle dia is 49mm hub bore is about 60mm Any ideas?
would help its a 1995 XJS coupe w/ 6cyl.
Old Nov 21, 2019 | 10:13 PM
Vee's Avatar
Vee
No idea which of the 21 model year cars you have. Which engine?
Do yourself a favor and create an automated signature so that you'll never have to worry again.
Old Nov 21, 2019 | 10:19 PM
Doug's Avatar
What year is your car? Or the last six of the VIN? There are two different hubs and they seal are different. I'm pretty sure it's a matter of with/without ABS
Old Nov 22, 2019 | 09:13 AM
lasstss's Avatar
its a 1995 XJS 6 cyl with ABS. Has wheel speed sensors.
Old Nov 22, 2019 | 03:59 PM
warrjon's Avatar
I have an 89 with ABS and had the same issue. I found XJ40 seals were exactly the same as the originals that came out.
NebRuss
XJ40 ( XJ81 )
Sep 27, 2016 07:48 PM
Daim
Sep 11, 2016 03:33 AM
srpope80
Apr 29, 2015 10:40 PM
RuJ
Jul 1, 2013 05:19 AM
Grant Francis
Feb 7, 2011 05:49 AM
