Screws under dash panel
Old Mar 5, 2014 | 02:17 PM
sidescrollin's Avatar
Default Screws under dash panel
Can anyone find a part number or show me a picture of the screws that secure the panels under the dash?
LONG ago when my dad cut my ignition key he removed the panel and simply put it back in place to test drive. It sticks pretty well and has been ignored for far too long.
trouble is I can't find anything specifying what those screws look like. I also can't locate the screws that go in the panels that enclose the steering column
Old Mar 5, 2014 | 09:19 PM
malc4d's Avatar
On my '92 the drivers side is is held on by a clip in the middle and has a plastic screw on the door B post near the top hinge. Passenger side has 3 or 4 screws holding it up.
Knee Bolster and Underscuttle Casing - Parts For XJS from (V)179737 to (V)226645 | Jaguar Classic Parts UK
http://www.jaguarclassicparts.com/uk/jaguar-xjs-v139052-v179736-parts/interior-trim-and-linings/body-interior-fixtures-and-fittings/knee-bolster-and-underscuttle-casing
http://www.jaguarclassicparts.com/uk...scuttle-casing
Old Mar 5, 2014 | 09:45 PM
Doug's Avatar
I recall the the underdash panels were held up with black trim screws....the type with the oval head using the little cup-like washers underneath. They screw into 'U' clips or 'J' clips.
The upper and lower column shrouds use machine screws.
I can't remember the sizes on either. I have large assortments of each and just grab something that works :-)
One time a pal of mine when looking at some Jags in wrecking yards and brought me back a jar full of black trim screws. Really comes in handy!
Old Mar 6, 2014 | 09:13 AM
Peel86XJS's Avatar
I found the same type of trim screws in packages at a few auto stores. Black with the cups in assorted lengths. I picked up several packages and replaced existing worn/rusted trim screws. I also used them for under the dash. They seem to work fine with the existing clips.
Old Mar 6, 2014 | 03:29 PM
I guess I'm just going to have to use my best judgement on this one
Underscuttle Casing - Parts For XJS from (V)139052 to (V)179736 | Jaguar Classic Parts UK
You can see the holes I'm talking about in this diagram and there is nothing in the diagram about the screws....it doesn't even depict them existing lol
Rivguy
Nov 13, 2022 02:55 AM
al_roethlisberger
Sep 21, 2015 08:07 PM
British Ride
XJ40 ( XJ81 )
Sep 18, 2015 01:57 AM
cyber3d
Sep 15, 2015 02:37 PM
sadepol01
Sep 11, 2015 05:26 AM
