Simply Performance centre box replacement pipes
Old Aug 26, 2018 | 01:36 PM
leo_denmark's Avatar
Default Simply Performance centre box replacement pipes
I have mounted these and will share my experiences
Communication has been clear and easy
Delivery: A few days (UK to Denmark, not that far)
Finish and initial quality feel: A+++ Really nice
Fit: Good. SP has made a joint where the centre box used to be, this makes it possible to rotate the 2 ends of the pipe relatively to each other. A good idea, when you fit a new pipe into existing exhaust.
Problems: My LH pipe from downpipe to SP pipe has come closer to the heat shields and creates some resonance now. I hope to solve it by taking the rear parts apart and aling things better.
External sound:There is more. Not surprising. There is a deep rumble in idle, only 3-5 dB louder than before. Take a listen to the videos to get an idea,
Interior sound: There is more, but not much. You hear a lot more rumble at low speed, but it fades out to almost normal level at cruise speed. At 130+ kph there is more noise as well. Again: View the videos.
Old Aug 26, 2018 | 02:14 PM
Daim's Avatar
Sounds PURRRRRRfect! Just how I imagined a V12 to sound...!
Should sound awesome with all the Simply Performance exhaust parts I am getting sometime
Last edited by GGG; Aug 27, 2018 at 03:02 AM. Reason: Make a comment like that again and you'll be GONE
Old Aug 27, 2018 | 12:57 AM
Dukejag's Avatar
That sounds assume indeed.... need to start saving.
Will not be for a while in my case, where are the kids bank books!
No cost on their website.... what are these worth?
Old Aug 27, 2018 | 04:54 AM
Crackerbuzz's Avatar
Old Aug 27, 2018 | 04:59 AM
Just did a similar video...
https://youtu.be/FPgR9AF1nMg
Mack
May 21, 2015 08:31 PM
tommaso
May 31, 2014 07:36 PM
DGL
Apr 15, 2014 09:34 AM
Diamondrmp
Nov 13, 2013 09:49 AM
