so has anyone actually made 500bhp from a v12 pre.he
Old May 11, 2017 | 04:05 AM
  #781
xjr5006's Avatar
Originally Posted by Como
Does anyone know anything about these heads? They appear on this company's website and appear to be new castings.
MFC PATTERNS & CASTINGS. - GALLERY
The combustion area looks pretty unique. Are these based on a flathead or a HE head?
followed this up quite deeply a while back. The patterns are privately owned an no longer with MCF , the owner was drag racing and hoping for huge HP, he never got it and basically gave up. The ports are too large t work properly even for me! Also a funny shape internally which I know was altered on 1 pair by adding Ali based resin. I lent a Gp 44 CA head with a much smaller 42mm port but the chap went his own way sticking with his altogether larger set up. Shame, the chap basically LS1'd the V12 Jag heads, I think there is great merit in what he tried to do but he went too big from the start; No one here will have anything approaching this chaps budget, just shows that a big bank balance is no guarantee of success
Old May 11, 2017 | 09:44 AM
  #782
icsamerica's Avatar
Just a quick update I spoke to Calvin today on the phone for awhile. The project is stalled but not dead. He is still passionate about it and wants to finish it. Calvin's current passion is a LS 5.3 turbo engine going in an off topic car. When I met Calvin I was intrigued by his ambitions and after speaking to him I learned nothing has changed.
Old May 12, 2017 | 09:29 AM
  #783
Jonathan-W's Avatar
they might be good with a 7 liter or larger engine... something really Huge!
and totally custom pistons made t work with that head
Old May 12, 2017 | 01:37 PM
  #784
Paul_59's Avatar
Banned
if memory serves this was an 8 litre forced induction V12 which as the more knowledgeable poster stated had serious amounts of ££££'s thrown at it without achieving target output of in excess of 800bhp
Old May 12, 2017 | 05:30 PM
  #785
warrjon's Avatar
Yep.
A point well made.
These heads have quite small ports (35mm at the SMALLEST point) and made 615hp from 6.0L. Chambers were kinda copied from the Austin head.
Old May 16, 2017 | 05:27 PM
  #786
ronbros's Avatar
some of these turbo'd LS 5.3L are making over 1000hp, using factory stock bottom ends! NICE.
Old May 16, 2017 | 09:30 PM
  #787
icsamerica's Avatar
Yep... those are the iron block variety. Its quite amazing... I've recently returned to the 1/4 mile track as a sport and the sheer quantity of car in the 10's and 11's that are driven to the track is astonishing.
I just pickup up a LS 6.0 with a 4l80E for a great price. With stock heads and cam 600HP is possible with 9 PSI. 700 to 800 HP if I can figure how to fit an intercooler and work the top end a bit. I gotta find something to put it in becasue My XJC coupe's chassis is overwhelmed by the engine it has now so a more powerful one is not an option. I'm thinking its going in an XJS with flared rear wheel wells. Could be the first streetable 10 second xjs.
I'm going to suggest this idea is loosely relevant to this thread simply becasue this was Calvin's idea and we discussed the technical over the phone.
Old May 17, 2017 | 01:57 PM
  #788
ronbros's Avatar
quick pix of my Buick GN converted to an LS 6.0L, iron block , aluminum heads #317. drive by wire TB.
and 4L80E trans. nice setup , Gn's light weight, and perfect 3.42 LSD.
would be great with turbo system, those LS engines are MAGIC with forced induction!
Attached Thumbnails so has anyone actually made 500bhp from a v12 pre.he-buick-cute-dogs-015.jpg   so has anyone actually made 500bhp from a v12 pre.he-buick-cute-dogs-010.jpg   so has anyone actually made 500bhp from a v12 pre.he-buick-cute-dogs-013.jpg   so has anyone actually made 500bhp from a v12 pre.he-buick-cute-dogs-012.jpg
Old May 17, 2017 | 03:19 PM
  #789
Flint Ironstag's Avatar
Heh - I always find it amusing when I can see the ground from topside of the engine bay. No chance of that with the V12!
Old May 17, 2017 | 08:01 PM
  #790
Como's Avatar
Hi XJR 5006. Thanks for the interesting history of the head. Would it be possible to CNC mill a similar combustion chamber into a HE head if a scan was available?
Old May 18, 2017 | 01:14 PM
  #791
ronbros's Avatar
even if you weld/filled in , you could do a nicely developed chamber!
but the ports would need a lot of work,Exhaust mostly!
be simpler and cheaper to get a set of race heads(xjr5006) also there is a guy in Australia who has some new ones, search this site ,he was on back few months,with some pix!
Old May 18, 2017 | 11:18 PM
  #792
warrjon's Avatar
Simple answer is no. As Ron said you would need to fill in the exhaust pocket. Those heads and the ones I posted have the chambers machined into pre-HE heads.
HE heads can make a good street engine. Peak HP is of little use on the street. A broad power band is what is needed. I have seen HE 6.0L engines make 450HP with 150hp available from 1500rpm.
Old May 19, 2017 | 06:26 AM
  #793
Paul_59's Avatar
Banned
Very interested to hear any details you might have on what's needed get that kind of output
Old May 20, 2017 | 04:57 AM
  #794
warrjon's Avatar
De-shroud the valves, these heads have had a fair bit removed to increase the chamber size to get CR down on a 6.7L engine, but they give you an idea of what is needed. Also o a 6.0L a cam would be needed that allowed 7000rpm. The stock cam has 0.374" lift and NO overlap 13/55 55/13 seat to seat.
A good low restriction exhaust and manifold ditch the stock air boxes and use elbows similar to XJ40 V12 or better still cut the plenums off and add larger ones to the standard runners.
Old May 20, 2017 | 11:37 AM
  #795
ronbros's Avatar
warrjon, looking good !
my take on cam choice, that factory 6.0L would be great for a forced induction engine!
my choice would be any factory V12 cam made before 1981!
or a custom race cam, cost may be prohibitive tho, plus all the work getting tappets and clearencing correct!
ron
Old May 20, 2017 | 05:20 PM
  #796
warrjon's Avatar
I have discussed this with Norm and all the cams that Jaguar used both V12 and XK were the same timing 13/55 55/13 no overlap. The differences were in the ramp and lift, but this was minimal.
Even with the stock cam the 6.7L should spin to 6000rpm with power peak at 5500rpm.
He has advised me to stick with the stock cam as the engine will make monster torque. I will need to change the diff ration from 3.58 back to 2.88 to help with traction in the lower rpm range.
Old May 22, 2017 | 07:54 PM
  #797
ronbros's Avatar
warrjon, if those cam timing specs are correct,that cam has a theoretical overlap of 26*, subtract lash clearence its around 18/20* overlap,roughly!
those specs say its an extremely mild performance cam. just might work with the 2.88 gear?? donno.
torque peak may be around 1500rpm, but i'm seein torque dropping off at 3500rpm there about.
time will tell, for sure an unusual engine combination.
ron
Old May 23, 2017 | 03:20 AM
  #798
warrjon's Avatar
Yes you're right with the overlap, this is the stock cam according to the ROM.
Old May 24, 2017 | 12:37 AM
  #799
Mobeck Tekniske's Avatar
Facebook Post
TWR Gr.A replica
Ole Mobeck
Forside - mobeck.com
Old May 24, 2017 | 10:01 AM
  #800
Jonathan-W's Avatar
Originally Posted by Mobeck Tekniske
how much did that cost you?
