Speedo Problem on 'Carmen' 4.0L XJS
Old Aug 14, 2018 | 04:54 PM
orangeblossom's Avatar
Default Speedo Problem on 'Carmen' 4.0L XJS
Hi Guys
Got a bit of a problem with the Speedo on 'Carmen' my 4.0L Six Cyl XJS that I've never come across before
When I went to Start her up, the needle on the Speedo suddenly went right over to 150 MPH even though the Car was stationary and then the needle stayed there and wouldn't return to Zero when the Car was switched off
Even with the Battery disconnected
Any ideas?
Old Aug 14, 2018 | 05:50 PM
Robman25's Avatar
No real idea but perhaps the transducer wiring on the rear half shaft is shorting out?
Old Aug 15, 2018 | 05:44 AM
bigpigpants's Avatar
I’ve had this happen & to get the speedo needle back to zero I had to remove the instrument cluster & whilst holding it, rotate it through 180 degrees anti clockwise to get the needle vertical & then rotate it another 90 degrees anti clockwise to get the needle back to zero. Mine was related to having the battery discharge over a period of time & then reconnecting a charged battery & turning on the ignition - AKA just one of those things!
HTH
Andy.
Old Aug 15, 2018 | 06:14 AM
HTH
Andy.
Hi Andy
Same thing seems to have happened with mine!
Battery went flat, put on a New Battery, Speedo went right over to 150 mph and Stayed there!
When you say rotate the Instrument Cluster, did you mean the whole 'Binnacle' or take the Speedo out of the Cluster first?
It sound like you meant the whole Cluster but just want to double check
Old Aug 15, 2018 | 07:42 AM
Steve M's Avatar
You should only rotate the whole cluster by the light of a full moon when Uranus is ascending.
Or you could just roll it into a ditch.
Old Aug 15, 2018 | 08:27 AM
Hi Steve
I'm not going anywhere at the moment, She won't start!
Old Aug 17, 2018 | 12:30 PM
I just removed & rotated the whole cluster - no need to remove the speedo itself from the cluster.
Kariblay
Jul 30, 2019 06:36 AM
Jaguar Mike
XJ40 ( XJ81 )
Dec 7, 2015 10:19 PM
sailor
XK120 XK140 XK150
May 9, 2015 01:47 PM
hoff38
Jul 16, 2014 03:57 AM
Brent Malowney
Jul 28, 2013 06:33 PM
