Speedometer dead again...
Old Oct 20, 2020 | 03:55 PM
sd63141's Avatar
Default Speedometer dead again...
So after taking out the instrument cluster and cleaning the contacts the speedo worked great for about a day. Now when I turn the car on the needle doesn't even move off the mechanical stop (as if it is not receiving any power). So next i'm going to open her back up and add an extra Earth wire. Anyone have any recommendations as to where I should connect it on the cluster? Other than the extra earth is there anything else that could be causing it?
Also on the attached photo can anyone tell me what lead I am pointing at with the pencil? It seems to be pretty beat up and half way torn. Thanks for the help!
- Scott
1992 XJS V12
Old Oct 20, 2020 | 05:43 PM
jag-reflex's Avatar
Ok, no offence, but what did clean the contacts with? Because, if that was mine I'd start again. You need some deoxit or something..unless the picture is not a good representation..those tabs should shine. I had, at one point, an image showing which tabs were grounds but I've put it in a mystery place (it's a mystery to me) so I'll start hunting..
Old Oct 20, 2020 | 05:54 PM
sd63141's Avatar
No offense taken, I took that picture when I first pulled it out prior to any cleaning. Thanks for the help hopefully you can find the picture that would be great.
Thanks,
Scott
Old Oct 21, 2020 | 02:08 AM
Greg in France's Avatar
The attached is the pre facelift data, I do not know if the facelifts are different. BUT, the safest way is to look at the plug that goes into the binnacle and determine the loom wire colour, then look up on a wiring diagram what this is. Alternatively, and probably more certainly, with a pencil, follow the copper on the blue circuit thingy from the plug and see where it ends up.
Old Oct 21, 2020 | 12:54 PM
sd63141's Avatar
Ok great thanks for the help!
RMR
Dec 15, 2020 11:26 PM
orangeblossom
Nov 3, 2018 11:26 AM
max224
Sep 23, 2018 01:20 PM
paulyling
Feb 7, 2017 05:36 PM
marke
Jan 3, 2015 11:17 PM
