Speedometer short? or something else
Old Dec 10, 2020 | 08:08 PM
sd63141's Avatar
Default Speedometer short? or something else
So the "Anti-Lock" and "Brake" lights have been on for a while (still getting around to diagnosing those problems) but I have been chasing an intermittent speedometer reading for a few weeks now. I have pulled the cluster out and cleaned the contacts and leads so everything has a good connection. Everything was working for about a week then this evening while driving the Speedometer would go dead, then wake back up, then go dead and wake back up, finally going off all together. However, I just noticed that the "Anti-Lock" and "Brake" instrument lights would both go out when the speedometer would drop off, then illuminate when the speedometer came back online.
Is this a short in the cluster, something to do with a speedometer sensor, or something different all together?
Any input would be much appreciated.
1992 XJS V12
Old Dec 11, 2020 | 06:27 AM
orangeblossom's Avatar
Hi Sd
Sounds like you've got a bad earth and if so its not unusual to rig up a supplementary earth behind the Instrument Cluster
Though do make sure that all the Pins on those Multiplug Plugs and Sockets are absolutely clean with no corrosion in sight whatsoever, as this is one of the major reasons for the Speedo to intermittently fail as it has on your Car
'Grant' advises 'Lemon Juice' for this sort of thing, which can be applied with a 'Cotton Bud' and that was one of the things that worked for me and also be very careful not to damage the Printed Circuit, or that could be a very tricky problem to sort out
Old Dec 11, 2020 | 07:17 AM
Doug's Avatar
I agree with OB. I'd take the cluster out again and double check everything and add that extra ground. If no joy then start looking for something more esoteric.
Old Dec 11, 2020 | 05:46 PM
sd63141's Avatar
Thanks Gents. I’ll give it another crack.
Old Dec 14, 2020 | 09:20 PM
afterburner1's Avatar
Good point, OJ, about the printed board. My printed circuit for the instruments and lights had burned traces. Bought trace material on Ebay. Trace materal is copper with adhesive on one side. Just stick it on your printed circuit and tack solder to complete the circuit
Old Dec 14, 2020 | 09:25 PM
sd63141's Avatar
AB1, thanks for the advice. I’ll definitely keep that in mind if the ground wire doesn’t work or if I see any charred areas!
RMR
Dec 15, 2020 11:26 PM
sd63141
Oct 21, 2020 12:54 PM
4mugen20
May 23, 2020 07:47 AM
dwight looi
Apr 28, 2015 04:07 PM
