Split front brake calipers?
Old Jul 6, 2020 | 03:01 PM
petemohr's Avatar
Default Split front brake calipers?
The manual says "DO NOT under any circumstances ..." split the caliper halves.
Is this really a killer move or can it actually be done safely?
I'm asking as I went and split them before I read the manual.
Yeah, I know . . . . .
Old Jul 6, 2020 | 07:03 PM
garethashenden's Avatar
It depends, I think, on whether or not you have the square section seals in your rebuild kit. Some have them, some don't. The kits I got from Rock Auto do include these seals. In my particular case, I split the calipers and then decided they were too far gone to rebuild myself, so I got some remans. But don't put them back together with the old seal, that's just asking for trouble.
Old Jul 6, 2020 | 08:00 PM
JayJagJay's Avatar
On Rock the core charge is almost greater than the actual part. They are an important bit. I would just get new or reman.
Old Jul 7, 2020 | 06:42 AM
petemohr's Avatar
I've decided to just get some reman calipers from NAPA.
They're black coated and "Semi-Loaded" for $72. Not too bad.
https://www.napaonline.com/en/p/SEBS...=brake+caliper
Old Jul 16, 2020 | 09:18 PM
Dleit53's Avatar
I have split XJS and similar calipers several times. I never had a problem afterwards.
Old Jul 17, 2020 | 06:43 AM
petemohr's Avatar
Default Update
New rotors, calipers and pads installed. No more pedal bouncing! Pretty easy job.
Thumbs up to the NAPA calipers. 20% off plus free shipping. Good deal.
The "weather-proof black coating" is a real plus for me (unless you want a color other than black).
Old Jul 17, 2020 | 08:54 PM
ronbros's Avatar
i use an aftermarket frt calipers WILLWOOD, red color , light weight aluminum, EBC slot rotors!
work fine been years , altho i rarely need hard use, but they feel good, its time to bleed the system and replace fluids!
i also use an aluminum master cylinder, Ford truck!
i can also change pads , without removing the calipers, center bolt holds pads(remove one bolt slide pad out ,slip new one in,bedone)?
patpayne
May 20, 2020 10:51 PM
Geezer
Oct 17, 2016 06:19 PM
barrymk2
Mark V - X 420G
Oct 25, 2013 03:17 AM
alexgb
Jul 19, 2012 03:41 PM
Thermo
Feb 9, 2009 05:15 PM
