standard bolt pattern (PCD) size?
Old Feb 14, 2008 | 12:47 AM
vexred's Avatar
Default standard bolt pattern (PCD) size?
hello frens,
just want 2 ask, does anyone know the stock standard bolt pattern size (PCD) of the 5.3 V12 XJS? cos i wanna swap out the ugly standard rims and fit 2-piece 18s as my 2JZ engine is currently being fitted into the XJS... if the PCD is unsuitable i'll probably have the knuckle either changed for the mk4 supra knuckles or modifed to PCD 114.3 so it's easier 2 find big fat wheels. the reason i'm not measuring it myself's cos da car's in the workshop and it's closed this whole week my car's locked inside [&o] never paid attention before haha!
also what're the specs of the XJS brakes? u know i can't even remember whether da car's rear brakes are drum or disc. that's real sad, no? can anyone shed any light on how many 'pot' are the front and rear brakes? thanks a lot jus wanna know ASAP so i can take immediate action this coming monday. cheers!
Old Feb 14, 2008 | 11:28 AM
ken@britishparts.com's Avatar
Default RE: standard bolt pattern (PCD) size?
Don't know about the wheel pattern.
The rear brakes are inboard disc brakes up to 93.5 and outboard after that. What year is yours or what's the last six of the VIN?
Old Feb 18, 2008 | 03:21 AM
vexred's Avatar
ORIGINAL: ken@britishparts.com
thx anyways i already got it measured the other day. it's 120mm... meaning i'll either have 2 mod the knuckle if i wanna get 114.3mm PCD rims or find rims that suit beemers and volvo and other euro cars i guess... rims 4 euro cars here selection's not 2 good as compared 2 japanese rims with 114.3mm PCD. will see how it goes.
Old Feb 18, 2008 | 09:38 AM
mghirsch's Avatar
Don't know the numbers, but the bolt pattern is the same as Chevy. However, the center hole is larger. If you can't find wheels with the correct centger hole, a good machine shop can enlarge the hole of the wheels you want.
aholbro1
Dec 29, 2024 06:46 PM
Gerard Radimaker
Sep 13, 2015 10:33 AM
chatmanx
Sep 11, 2015 07:17 PM
metalmarty
Sep 11, 2015 07:05 AM
