Starter motor replacement. Manual Xjs 3.6.
Old Mar 22, 2021 | 09:11 AM
krakenfelt's Avatar
Default Starter motor replacement. Manual Xjs 3.6.
Hi all, is there a way of removing the starter motor only from above? The bolt that goes through the bell housing is very tricky, is there a special socket adapter I don’t know of that can help?
Old Mar 22, 2021 | 02:28 PM
cactus's Avatar
Hello,
I don't know if it's the best one....It was my solution:
Please note that the bolt is not imperial 1/2 inch but Metric 13mm
Old Mar 22, 2021 | 03:38 PM
krakenfelt's Avatar
😂 I love this contraption! I will attempt tomorrow. I was searching for a U shaped socket adapter/extension, but couldn’t find one, surely that would work for many situations, like this? Or am I missing an obvious physics issue here..
Old Mar 22, 2021 | 04:01 PM
cactus's Avatar
Not tested.....Maybe this one could be an other solution ?
Old Mar 22, 2021 | 04:44 PM
krakenfelt's Avatar
I’ve tried searching for such a thing and couldn’t find anything, I tried 180 degree socket adapter and U shaped socket adapter, does it have a specific name?
Old Mar 22, 2021 | 05:09 PM
cactus's Avatar
In french name is "desaxeur"
=> I don't know how to translate in english
But my fisrt solution is OK.
You just need a good quality 13mm wrench angled ring head (for me god quality mean perfectly fiting to the bolt in order not to damage it)
The diffciculty is to unlock the bolt. After unlocking....turning with fngers is easy.
exjay8
Dec 14, 2019 10:30 PM
seanariel
Jun 3, 2016 03:50 AM
Roger Geirnaert
Oct 12, 2015 01:01 PM
