HELP! How to replace x-type starter motor
Old Dec 13, 2010 | 04:38 PM
seanariel's Avatar
Default HELP! How to replace x-type starter motor
I have a bad starter motor on my '04 X-type 2.5L that I need to replace.
I see the location of the starter and trying to find easier access to it.
I have Technical Service Publication for Jag but the process to replace it seems too complicated.
Has anyone replace their starter motor and know an easier way to replace it?
Thank you.
Old Dec 13, 2010 | 06:21 PM
sport30's Avatar
Banned
manual or automatic transmission?
manual cars are super easy to do. no need for instructions. it is too obvious.
Automatics are harder but I have never done it....
Old Dec 14, 2010 | 08:42 AM
seanariel's Avatar
Default it is a manual transmission
it is a manual transmission. could you explain how you've done it.
were you able to access from the top?
Thank you.
Old Dec 14, 2010 | 02:36 PM
sport30's Avatar
Banned
Everything fron the top.
Remove battery and battery box
Pull back rubber cover at end of starter solenoid and undo wires
Un bolt 2 bolts that attach the starter to the bell housing/ Transmission. - these are vertical bolts, you can see them looking straight down from above. One of them has a ground wire on it.
Then lift starter and wiggle its way out of there.
As a side note, the manual transmission starter motors can get a the bendix/pinion gear all gummed up with clutch dust, and then it wont engage properly and will make horrible grinding noises. This can be easily taken apart, cleaned, relubricated and put back into service.
Why are you removing yours?
Old Dec 14, 2010 | 06:18 PM
Nice one Sport30.....next time though, please complete the write up with pics attached and a full written how to for future use.....A video would also help!
This will gain you kudos on the site +500 bonus post count and elevation to senior member
Seriously, nice post .....
Old Dec 14, 2010 | 07:03 PM
seanariel's Avatar
Thanks a million Sport30!
And also for pointing out what causes the noise which is exactly why I'm planning to replace mine. I have 100K mi on the car and it started making the horrible noise at COLD start-up. This noise is heard only when the car is COLD. I'm sure this is not from the accessory belt though could be from the belt tensioner. So I wasn't 100% positive whether it is in fact from the starter but since you are also pointing out about it, it must be it!
BTW, is there any expected issue by disconnecting the battery such as need to reset anything?
Also, have you changed spark plugs on the car? Was it hard to access spark plugs?
I'll probably have to change my belt and the tensioner at the same time.
Thanks so much for help!
Old Dec 14, 2010 | 07:25 PM
benebob's Avatar
ud
Try spraying your belts with armorall before starting. See if the noise goes away. That should rule out your belts.
Plugs aren't hard, just time consuming as you need to take off the intake (or raise it up at the very least). My plugs were NASTY at 100k
Old Dec 18, 2010 | 09:42 PM
seanariel's Avatar
Sport30,
Did you have any problem removing the 2 bolts holding the starter?
First, I could not get to the bolts hence needed to remove the intak manifold to be able to reach.
Second, I could not turn the bolts. I lubricated, used different tools, but eventually broke my 3/8 inch adaptor and still didn't turn a bit.
How were you able to reach the bolts without removing the manifold? And what kind of tool did you use?
Thanks a million!
Old Dec 19, 2010 | 10:59 AM
sport30's Avatar
Banned
I used a long extension and was able to undo them without any drama.
Are you certain that you are getting at the right bolts? what is your email address? i will send a picture
Old Dec 19, 2010 | 08:37 PM
seanariel's Avatar
Thanks for your feedback Sport30. Fortunately, I was able to get it out and sucessfully replaced it. While taking out the manifold, I've got spark plugs done too which I needed to anyways.
Old Dec 20, 2010 | 02:00 PM
sidewalkman's Avatar
Just for future reference, I find 3/8 drive ratchets and sockets brutal on torqued bolts. I have 1/2 drive 6 point torque sockets and a, 18" extention and that will get pretty bolt undone...or snap it off in the process which is never fun.
Old Mar 11, 2012 | 10:55 AM
Ricardo Andres Lopez Walker's Avatar
Sport 30, i want to thank you for this post, it was great help for me. I am mechanically challenge but your post was fenomenal, i just finished fixing my wife's car and i did what you said about just cleaning the starter and it worked like a charm......great help bud. Thanks a million
Old Jun 3, 2016 | 03:50 AM
Windle2706's Avatar
Default X type starter motor
Hi Sport30,
I have just come across this post you put up a while ago about the starter motor. Im having similar problem with my manual 54 plate x type and want to get it off to clean it.
I stripped out the battery and casing and also the air intake and I'm trying to identify which bolts I need to take out to remove the starter. Is there any help you could provide please?
Aaron Windle
toronadomike
Jan 22, 2026 10:13 PM
Sprayall
May 30, 2021 08:13 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
Sprayall
Sep 3, 2015 07:49 PM
TC Johnson
Sep 2, 2015 09:30 AM
