Strange steering experience
Old Jul 4, 2016 | 10:50 PM
BC XJS's Avatar
My 86 has too much power assist. I get little feel thru steering wheel. Drives me nuts. The car does corner like it's on rails.
I think tire load rating, tire compound and tire inflation would make a huge difference in handling. I would expect that made the change in handling. Maybe I need lower load rating to get better feel.
Old Jul 5, 2016 | 01:43 AM
Greg in France's Avatar
BC, if the time ever comes that you need to replace the rack, the later ZF rack as fitted to facelift cars, has much more feel and less assistance than the earlier racks such as your car had from the factory. Goes straight in except that the tie rod ends are metric so you need to change them too, and the pipes may be different.
Greg
Old Jul 6, 2016 | 11:56 PM
BC XJS's Avatar
Thanks Greg. Good to know. Im going to try some 18inch wheels and tires and see if that helps. Ive read many forums re modified power streering pump but all seem to increase power assist not lower it.
Dam 4x4ers
Old Jul 7, 2016 | 10:18 AM
JagCad's Avatar
I would think:
1. The rack responds to driver input as assisted by hydraulic boost. Boost can be changed. At the pressure relief valve. spring tension, oriifice size, etc. On your pump, I can't say. Never saw one.
2. Wheel alignment and tire pressure. Differing driver input needed.
Example, more caster, more directional stability. but, more input needed.
Go out to your car and others. Look at the tire position at full lock!!
Carl
KayScotts
May 8, 2016 04:16 PM
vsol
Apr 15, 2016 07:11 AM
MonacoDK
Apr 5, 2016 08:30 AM
daves_ale
Apr 3, 2016 07:46 PM
Paul_59
Apr 3, 2016 04:55 AM
