Suggestions for installing aftermarket seat heaters.....
Old Dec 28, 2014 | 08:25 AM
Spikepaga's Avatar
Default Suggestions for installing aftermarket seat heaters.....
.......but making them work with the original switch.
My car did not come with seat heaters, and I don't think I want to buy a whole bunch of used OEM parts that are over 20 years old. The only thing I would like is to power and ground them thru the power supply intended for the factory seats and operate them from the factory switch, so it all "looks stock", so all I would have to buy is the aftermarket heaters and seat controls that come with the heater buttons
Has anyone done this?
Old Dec 28, 2014 | 11:12 AM
Safari's Avatar
If the seat heaters you buy do not come with relays then you will need to add them. The switches alone are not capable of the current needed to run the heaters.
It should be a simple installation. Everything will connect to the relays; 12V, switches and heater.
The other thing to consider is a timer. You might be able to find a timer/relay combination. That way the heaters will automatically turn off at a set number of minutes.
Its probably best to buy a complete heater kit that includes the relays, switches and wiring. Then you can just substitute the Jag switches for the ones that come with the kit.
Mark
Old Dec 28, 2014 | 12:44 PM
ronbros's Avatar
question; how much current does each seat use?
would a higher output alternator be required?
Old Dec 29, 2014 | 10:52 AM
Spikepaga's Avatar
Mark
Thanks Mark
Well I would like to use all the original wiring, relays and fuses. And just use the aftermarket heating elements if possible.
Old Dec 29, 2014 | 11:14 AM
Safari's Avatar
Thanks Mark
Well then comes the question if your car has the needed wiring. You said your car did not come with heated seats so I don't know if Jaguar used a different harness for those cars.
If you do have the wiring then you should be able to plug in the factory relays, fuses, switches and heater pads.
If you don't have the factory wiring then your better off to just get a complete kit and wire it in according to their instructions.
Mark
dsnyder586
Dec 29, 2024 07:39 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
KarimPA
Sep 12, 2015 08:15 AM
jagent
Sep 12, 2015 01:40 AM
Dallas XK8
Sep 3, 2015 12:17 PM
