Surge tank seal
Old Feb 12, 2021 | 11:02 PM
brinny's Avatar
Default Surge tank seal
Hi all, I need to replace the round rubber seal on the surge tank where the fuel outlet pipe comes through. Think this may be the cause of my fuel smell. Well pointed out Greg! Anyhow, is it possible to replace this without draining the surge tank and without removing it? Many thanks in advance
Old Feb 13, 2021 | 02:29 AM
Greg in France's Avatar
Brinny
You have to drain the tank to change the seal, as the tank is gravity fed from the main tank, you have no option. In theory you could pinch the 1/2 inch feed hose from the main tank, but the risk of damaging it by trying is far too high, and they are NLA.
As long as you can get to the drain plug, and the main tank is low, it is not too arduous.
I have long thought about a tap inserted into the feed from the main tank, which would be great, but I have never found one that did not leak, or look as if it would.
Old Feb 13, 2021 | 03:17 AM
Brake buster's Avatar
as above
i have NOS seals here in UK as i had to buy a pack of 5 from jaguar ,
i would also take the opportunity to clean out the swirl pot and ensure the gauze filter on the end of the pickup tube is in good order and replace the inline fuel filter to the engine
BB
Old Feb 13, 2021 | 03:49 AM
brinny's Avatar
Thanyou both
jaimster
Aug 20, 2020 02:29 PM
HIJaged
16
Nov 18, 2015 04:56 AM
carate
Aug 20, 2014 09:46 AM
bhamilton
May 18, 2014 04:55 AM
Jaguar2986
Sep 28, 2013 04:22 PM
