Thermostat Jiggle Valve
Old Aug 28, 2023 | 12:49 PM
Jeff Morris's Avatar
Default Thermostat Jiggle Valve
Still having problems with the bleeding of the system, which position should the Jiggle Valve be in on the Thermostat, would drilling a bigger hole help?
XJS 3.6
Old Aug 28, 2023 | 01:07 PM
Vee's Avatar
Vee
I thought that the six cylinder engines were all self bleeding. If you have a thermostat with the jiggle pin, it should be positioned at 12 o'clock.
Old Aug 28, 2023 | 09:15 PM
I remove those pins, and just have the hole, V12 or 6, same, same.
Check the small hoses that enable bleeding, they can and do, clog up due to lousy coolant spec under a PO.
Old Aug 28, 2023 | 10:35 PM
Hi Grant I will try removing the pins. The system should self bleed but i have to remove a small pipe to fill it even though the small pipes are clean and clear
Old Aug 28, 2023 | 10:48 PM
Vee's Avatar
Vee
What? That's not making sense to me...can you share a pic of the hose you need to remove?
Old Aug 29, 2023 | 03:14 PM
Any of the small hoses then the water fills up the system, the temp gauge is always below normal. When everything has cooled down and cold the Header tank is full to the top of the neck so if i remove any small hose water drains into the engine
Old Sep 7, 2023 | 03:02 AM
Jaguar xjs 3.6 I was sold a thermostat housing from a V12 saying it was indentical, needed a blanking plate though, I notice the jiggle valve is before the Tee for the small bore bleed pipe on my original housing, the V12 jiggle valve is after the tee therefore only acting on one of the pipes, my question is how much difference will this make to bleeding the sysstem
Vee
Aug 23, 2023 08:52 PM
Popstacle
Jan 30, 2023 12:24 AM
garethashenden
Jun 19, 2021 05:21 PM
rendo
Jun 14, 2016 03:39 PM
dkeuper
Oct 12, 2012 04:54 AM
