Throttle bushing replacement
Old Oct 21, 2012 | 11:28 PM
wagonerkl's Avatar
Default Throttle bushing replacement
What is the easiest way to replace the rubber throttle bushings? I am hoping it can be done without having to re-adjust the throttle plates. Any tips? Thank you.
Old Oct 22, 2012 | 12:06 AM
Doug's Avatar
No need to disturb the throttle plate adjustment (although periodic checking of the adjustment and cleaning the throttle bores is a good idea).
Bushing replacement require (at least partial) disassembly of the bellcrank-type lankage at the rear of each inlet manifold. Not difficult.
The true OEM bushings are fairly soft and easy to press into place. Some aftermarket types are a hard nylon or plastic....I've never been able to install these without some trimming. A few months ago someone posted about sing commonly available door hinge pin bushings that drop right into place. Pretty slick!
This would be a good time to adjust/synchronize the throttle linkages.
toronadomike
Jan 22, 2026 10:13 PM
Gus
Oct 15, 2019 12:29 PM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
RaceDiagnostics
Sep 7, 2015 07:28 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
