Throttle Position Sensor--which is best?
Old Sep 10, 2022 | 04:55 PM
EcbJag's Avatar
A couple years ago I went through 3 of the new "Bournes style" TPS and they were all crap out of the box. All 3 had more "blank spots" across their travel on the multimeter than the 30 year old one that came out of the car. None would consistently return to the same value at idle either. The new "Bournes style" are about half the weight of the original, clearly of poor quality, and I would caution anyone away from wasting their time on them.
The OP on this thread was my father and we both had much better luck with the red TPS in our Jags. Unfortunately the kit to adapt these units to older pedestals has been NLA for some time now. Great tip on using the old TPS as an adaptor for the new one. Will certainly use in the future. Thanks for sharing.
Old Sep 10, 2022 | 05:29 PM
Doug's Avatar
And I've had two of the red style fail in as many years; maybe less, actually. These being the brand-x replacements that Jaguar now sells.....not the Lucas originals
So I've been back on the Mustang type for a while now
Maybe one day I'll research other choices
Old Sep 13, 2022 | 09:45 PM
Rescue119's Avatar
Originally Posted by Doug
Not likely....but I actually don't know what colors Ford used.
I have notes on which wires go where....but it'll be a few days before I can put my hands on that info. I might've posted the info here or on J-L years ago so an archives search might be in order.
found this over there
Old Oct 10, 2022 | 12:05 PM
Rescue119's Avatar
Finally working on this today.
How do you get the shaft out of the old one?
I read cut it but where do you cut exactly m
Old Oct 10, 2022 | 05:22 PM
Rescue119's Avatar
I figured it out. I just cut open the original tps
So inital setup shows .329 volt and top end at 4.66 which is consistent from what I've read.
So now I need to decide if I should open up the new tps and shave off that spot to get it up to 5.0v or should i just leave it?
Opinions on those who have left it?
Katoh
Jan 21, 2025 01:20 PM
John Herbert
May 6, 2021 04:52 PM
BenKenobi
Oct 13, 2020 01:33 PM
SD96XJ6L
Dec 17, 2019 11:15 PM
Crackerbuzz
Mar 3, 2019 03:30 AM
