Timing Pointer
Old Jan 10, 2012 | 05:57 PM
87XJSCoupe's Avatar
It is on the bottom at 6:00 O'Clock and can only be seen from the bottom. If the car is on a lift, it is not too bad to see. If the car is on a jack or ramp, it can be very hard to see and read....especially with the car running at 3000 rpm. Mine is a 5.3 but I assume the 6.0 is the same.
Old Jan 11, 2012 | 03:35 AM
Yep.
The 6ltr pointer is at the bottom, and the 2 bolts that secure it, also secure the Crank Position Sensor, so it will be easy to see, NOT. You could maybe feel it easier than see it.
dsnyder586
Dec 29, 2024 07:39 PM
Wolfy
May 28, 2024 08:06 AM
PMKimpton
Aug 3, 2019 08:22 PM
nitrolouie2142
Sep 5, 2015 01:55 PM
Sprayall
Sep 3, 2015 07:49 PM
