tranny oil change
Old Oct 8, 2015 | 12:57 PM
brinny's Avatar
Default tranny oil change
hi all . im planning on changing the transmission oil and filter in my3.6 1987 xjs tomorrow. ive read about removing the dipstick and dropping the sump but having a quick look today it looks as if there is a drain plug. is this rare or was it a standard thing that I just haven't seen mentioned? many thanks
Old Oct 8, 2015 | 01:14 PM
Safari's Avatar
If you have a drain plug then that will make the job less messy. Easy to drain the old fluid into a pan.
But you will still need to remove the sump pan to replace the filter.
Mark
Old Oct 8, 2015 | 01:27 PM
brinny's Avatar
yes I thought that especially as I intend to flush it through , but I didn't think they had a drain plug? or do some cars?
Old Oct 9, 2015 | 03:23 AM
Some did, some did not.
One of mine did, the other 3, incluing the X300, nope.
Yours would possibly be a very early build date.
jeremys
Nov 2, 2015 12:53 PM
avio
Oct 29, 2015 08:33 AM
Pete142
Oct 11, 2015 01:06 PM
Charles Wan
Oct 6, 2015 09:12 PM
P999l
Oct 3, 2015 07:39 PM
