Transmission fluid check on xjs
Old Feb 5, 2016 | 05:38 PM
Qgregg's Avatar
Default Transmission fluid check on xjs
Ok i know this is probably dumb. Can someone tell me the process. To check transmission fluid 1988 5.3 v12 ? And if low what to do. Tks
Old Feb 5, 2016 | 05:52 PM
Steve M's Avatar
Run the car up to temperature, park it up and put your foot on the brake.
At tick over run through all the gears several times then leave it in Park.
With the engine still running pull the dip stick (brown handle below the right hand side cross brace, close to the fire wall, bit tricky so make sure you have a rag to hand), wipe it, reinsert it and pull it again and read it. Do this several times and take an average reading. Once you have determined the level and you decide that you need to top it up simply pour the correct amount (and grade) of ATF down the dip stick tube; using a long necked funnel helps a lot.
Old Feb 5, 2016 | 06:33 PM
Qgregg's Avatar
thank you and i just found the culprit, sprung a leak where the tranny fluid hose connects to rad. When i replaced the rad a few years ago it didnt have the compression fitting to screw onto just the nipple sticking out. So put a hose clamp there. Have to investigate more tomorrow thanks.....
Old Feb 6, 2016 | 05:18 AM
Adding to what Steve stated.
When pulling that dipstick out, be VERY careful, as there are a bunch of wires and small vac hoses in that area, and without care you can displace them, and havoc, bad language, alcohol consumption, follows instantly.
Old Feb 6, 2016 | 08:50 AM
Doug's Avatar
As opposed to just warming up the engine I find that it's best to drive a good 10-15 miles and get the fluid trans fluid HOT before checking.
It really *does* make a difference in the dipstick reading!
Just my 2-cents
Old Feb 6, 2016 | 06:02 PM
ronbros's Avatar
this is for Grant,, 1/4 million beer cans going to the brewery, for fill up.
Josh 6.4" tall for perspective,
Attached Thumbnails Transmission fluid check on xjs-dscn8677.jpg   Transmission fluid check on xjs-dscn8678.jpg
Old Feb 6, 2016 | 06:48 PM
DAMN,
When do we get them back FULL, HAHA.
Thanks for that, I need a top up now.
Old Feb 6, 2016 | 08:42 PM
plums's Avatar
You need a bigger truck ... that's only half of Grant's empties.
Old Feb 7, 2016 | 12:05 AM
Ya been looking?????
Old Feb 7, 2016 | 02:20 AM
plums's Avatar
Ya .. but mostly at your avatar
beats the guy in the baggy shorts holding the beer can by miles!
Old Feb 7, 2016 | 05:32 AM
paulyling's Avatar
No dumb questions Qgregg.....
I asked alot of them the last few years
There is lots of "beginner" eyes watching
The trans fluid is one I have asked as well...
Nookpad
Feb 7, 2016 09:06 AM
tcspivey
Feb 6, 2016 12:52 PM
Sabrina
Feb 4, 2016 07:16 PM
Qgregg
Feb 3, 2016 10:04 PM
NoelShort
Jan 30, 2016 11:13 AM
